02Day 03Hr 51Min 23Sec
How to add more menu items?
Viewing 16 reply threads
    • #17978
      postpuru
      I want to add more menu items. How to accomplish it? Also, I can’t upload Avatar, Store Logo and Product pics since that’s grayed out. Am I missing something?
    • #17981
      I am really sorry for the inconveniences.
      Kindly know me one thing, are you facing this issue as Admin login as well?
      If no and only as Vendor then it’s just capability issue.
      Do you have any user role editor type plugins?
      There is a filter called “wcfm_menus” which you may use to add/manage menu items.
      If you are not comfortable with PHP and WP coding then please know us, we will help you to achieve this.
    • #18010
      postpuru
      Alright, I found wcfm-view-menu.php page that is in the folder views. There’s an menu_active_dependent_list and filters. Let me know with one example how to add menu here. For example I want to add “hello” page as menu. How to add it there so that hello page can be navigated without leaving the dashboard. Thanks.
    • #18016
      I understand your requirement.
      Here is an example of the same for you – http://wclovers.com/wp-content/uploads/2017/07/new_menu_wcfm.zip
      Please know me if you required any further assistance on this from our end!
    • #18114
      Is this helpful for you?
      Please know me if we can help you some other way!
    • #18283
      Puru
      You just gave me a file. That absolutely doesn’t help. Why is it so difficult to get support from you? All I want is one easy instruction. Can you do that for me please? Give me the instruction of where to find files and replace with what set of codes/scripts. That will be quite helpful. Thanks.
    • #18284
      I am really apologize if that file is not helpful for you.
      But it’s not all difficult to reach me or getting any help from us, please keep in touch.
      Kindly know me what will be your menu name, I will write this for you.
      You just have to add your content in the page.
    • #18285
      Puru
      Thanks for prompt reply. I want to add these in the main navigation menu: Build, Service, Upgrade, Contact, Appointment. Highly appreciated.
    • #18286
      That’s fine. What will be the content of these pages?
      Or should I create empty pages and you will add content later!
    • #18287
      Puru
      I would like to put some short-codes. Is that possible? You may instruct me the places where exactly I can put the short-codes. Thanks.
    • #18290
      Yeah sure, you may execute short-codes there. I will fully instruct you, don’t worry.
      I will send you this by tomorrow morning (IST).
    • #18335
      I am just working on that and will send you in few hours.
      I am sorry for a bit delayed, we were totally packed up with the latest update!
      Thanks for your patience.
      Shhiv
    • #18342
      Here is your custom code – https://drive.google.com/file/d/10sL7Bcer1xBheUq6vd5Yvcu2qQ1A4Sc4/view?usp=sharing
      It’s a complete plugin so you just have to install this as another plugin in your site.
      You will find views files under “wcfm-custom-menus/views” and have to define your own content at “Add Content Here” area.
      It’s also possible to define separate CSS and JS for each screen, I have defined those only for “Build”.
      Please know me if you have any queries.
    • #18534
      Didn’t hear back from you so long?
      Is this works for you!
    • #19023
      postpuru
      Everything went well. Thanks a lot! Thanks a million!
      Is there a way to block WordPress Admin section or top line for non-admin users or vendors? Appreciated.
    • #19041
      Ah … I though you just for get us or may be very angry on me .. lol
      That’s really pleasure to know that things are working as per your expectation.
      For hiding top bar you may just use such a simple plugin – https://wordpress.org/plugins/hide-admin-bar/
      WCFM already has a option to Block backed access for Vendor users.
      If you are using WCFM – Groups & Staffs then you may do the same for Shop Manager an Shop Staff as well.
      Please know me if I can help you some other way!
    • #19854
      Bingal
      Keymaster
      Please know us if you required any further assistance from us.
  • The topic ‘How to add more menu items?’ is closed to new replies.
