Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › How to add "Store Manager" link in Vendor Header Top Menu
- This topic has 3 replies, 2 voices, and was last updated 5 years, 5 months ago by
Kreator.
- April 4, 2020 at 10:41 pm #115428
Kreator
I am using Martfury and if I log in with a Vendor account I do not get the “Store Manager” item in the header bar top menu.
I only get:“Hello …”
“Log out”This is not usability friendly so please let me know how can I add a custom link to Store Manager ONLY when a Vendor is logged.
I want to be something like this:
“Hello …”
-> “Go to Store Manager”
“Log out”Thanks!
- April 5, 2020 at 10:41 am #115548
Kreator
ParticipantIt seems it builds an array of two elements but it is empty.
Anyway, I have attached a screenshot of where I want to add the two links:
1. The Store Manager link
2. Add/Edit Products linkThis should be available only for the Vendor user type.
You must be logged in to view attached files. - April 5, 2020 at 11:20 am #115561
Well, this will be best to contact theme support for this.
Martfury already directly compatible with WCFM, so they can add this easily in their theme core.
- May 6, 2020 at 11:11 am #127272
Kreator
ParticipantOk thanks. You can close the topic.
