Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › How to change/remove the "brands" while adding products
- This topic has 3 replies, 3 voices, and was last updated 5 years, 4 months ago by
Sarmistha Chakraborty.
- May 7, 2020 at 5:00 pm #128023
rohitxd
ParticipantHi I want to make this part invisible https://prnt.sc/scj8yr
or else I want to change the label name of Brands https://prnt.sc/scj8yrPlease respond how to do both, I would appreciate…
Thanks - May 8, 2020 at 2:00 pm #128314
To make this part invisible,
add_filter('wcfm_is_allow_custom_taxonomy_pwb-brand', '__return_false');
to change the label name of Brands https://prnt.sc/scj8yr-
add_filter( 'wcfm_taxonomy_custom_label', function( $wcfm_taxonomy_custom_label ) { if($wcfm_taxonomy_custom_label == 'Brands') { $wcfm_taxonomy_custom_label = 'Rename Brands'; } return $wcfm_taxonomy_custom_label; },15);
- June 11, 2020 at 8:59 am #140496
djks74
I did add this filter to remove brands on the product edit page but Brand still appearing.
Please advise! Thanks- June 11, 2020 at 11:54 am #140522
>>Can you share a vendor details with us.
Which plugin/any custom code are you using to create a product brand?
this code will applicable for https://wordpress.org/plugins/perfect-woocommerce-brands/Thanks.
