Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › How to change the text and remove/hide order field on booking section?
- This topic has 6 replies, 3 voices, and was last updated 6 years ago by
Sarmistha Chakraborty.
- May 18, 2020 at 9:19 am #132404
simon99299
ParticipantHi. I would like to ask about
How to change the text and remove/hide the order field on the booking section?
I’ve attached the screenshot to deliver my inquiry exactly.
Looking forward to your reply
You must be logged in to view attached files. - May 18, 2020 at 6:58 pm #132651
To hide “order field ” from booking list add below css in your theme’s style.css –
.wcfm-dashboard-page table#wcfm-bookings th:nth-child(4), table#wcfm-bookings tbody tr td:nth-child(4) { display: none; }Make unable to access vendor’s shop –
>>Add this code n your theme’s functions.php –add_filter('wcfm_store_name', function($store_name){ return __( 'My Store h', 'wc-frontend-manager' ); });To change Product text to “Teacher”-
You can use Loco Translate plugin – https://docs.wclovers.com/locotranslate-translation-using-loco-translate-plugin/
Select Loco translate -> Plugins -> WCFM – WooCommerce Frontend Manager -> Select Site language -> Search string (like Product) and change -> SaveThanks.
- June 5, 2020 at 5:53 pm #138796
testpaid2322
ParticipantHow to change inquiry title to Enquiry on frontend.
You must be logged in to view attached files.- June 5, 2020 at 7:41 pm #138830
Please use “Loco translate” plugin for this.
Wordpress dashboard -> Loco translate -> plugins -> select plugin WCFM – WooCommerce Frontend Manager -> select site language -> search string “inquiry” -> change and save.
Ref : https://docs.wclovers.com/category/loco-translate/Thanks.
- June 6, 2020 at 10:54 am #139014
testpaid2322
ParticipantThank you for the help..
- June 6, 2020 at 10:50 am #139010
simon99299
ParticipantHello
How to hide “End Date field” from booking list?
You must be logged in to view attached files.- June 6, 2020 at 9:15 pm #139110
MemberAdd the css –
.wcfm-dashboard-page table#wcfm-bookings th:nth-child(6), table#wcfm-bookings tbody tr td:nth-child(6) { display: none; }Thanks.
- The topic ‘How to change the text and remove/hide order field on booking section?’ is closed to new replies.
