Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How to customize add product page
- This topic has 8 replies, 2 voices, and was last updated 7 years, 2 months ago by
- June 30, 2018 at 4:28 pm #25691
wwsAdmin
ParticipantHello Team,
i would like to change/customize add product page. would like to rearrange some code. and change some wording.
- July 1, 2018 at 5:49 am #25709
Word change is easily possible using Translations process.
But, what kind of layout customization you are looking for?
- July 1, 2018 at 12:17 pm #25722
wwsAdmin
ParticipantNot word change. i am looking for layout change. like moving Downloadable checkbox in simple product below the dropdown. and adding blubber/help text (?) which will give additional info on hover. such kind of changes
- July 1, 2018 at 4:46 pm #25734
Then you have to edit plugin core files and hence you can’t update WCfM any more!
Hope you are fine with this?
Check under – wc-frontend-manager/views/products-manager/wcfm-view-products-manage.php
- July 1, 2018 at 6:58 pm #25740
wwsAdmin
Can we copy the files in theme directory similar to woocommerce ?? And edit it so that update will also happen
- July 2, 2018 at 6:18 am #25786
Right now it’s not possible.
It will be possible fromm WCfM next update, kindly wait till then.
- July 4, 2018 at 12:21 pm #25869
WCfM 4.1.7 has already released and it comes with template override option.
- July 4, 2018 at 12:42 pm #25874
wwsAdmin
Thanks for the update.
Can you help me with document which can help?
- July 4, 2018 at 12:47 pm #25877
Sorry, documentation is not yet updated for this.
It’s very easy to do.
Check at – “wp-content/plugins/wc-frontend-manager/views”
There is a folder named “products-manager”
Override this at – “yourtheme/wcfm/”
- The topic ‘How to customize add product page’ is closed to new replies.
