How to disable product limit from php
Multi Vendor Marketplace Plugin | WCFM Marketplace Forums WC Marketplace How to disable product limit from php
Viewing 2 reply threads
    • #75978
      me
      I’d like to override my default product limit settings in certain specific cases, so I need to be able to control it within php “if” statements.
      Can you give me a piece of code that would override the default product limit?
      Thanks a lot!
    • #76223
      Do you mean store page product limit?
      If so, then you may use this code –
      add_filter( 'wcfmmp_store_ppp', function( $post_per_page ) {
      	$post_per_page = '50';
      	return $post_per_page;
      }, 50 );
    • #76414
      me
      No, I meant product limit from capabilities. I want to override the default setting.
