Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › How to disable store sidebar
- This topic has 3 replies, 2 voices, and was last updated 7 years, 1 month ago by
- January 28, 2019 at 11:35 am #45551
tralltrangna
ParticipantHello! I can’t disable vendor sidebar although I uncheck it in the settings menu. How to disable it? and one more question how to edit the filter list for vendor store sidebar?
Thank you in advance!
You must be logged in to view attached files. - January 28, 2019 at 11:40 am #45562
That setting is good enough to disable Store page sidebar.
Well, what kind of modification you want to make at Store List sidebar ?
- January 28, 2019 at 11:45 am #45563
tralltrangna
ParticipantYes, but for some reason does not turn off this sidebar from me.
I want to remove the filter by country and search, I want to leave only the search by category. - January 28, 2019 at 3:39 pm #45575
“Yes, but for some reason does not turn off this sidebar from me.”
– That’s quite impossible. Do you have override template for editing?
and what is your WCFM Marketplace plugin version?I want to remove the filter by country and search, I want to leave only the search by category.
– Use this short code for store list page –[wcfm_stores search='' country='' state='']Thank You
- The topic ‘How to disable store sidebar’ is closed to new replies.
