Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › How to get the store id for using it in short code
- This topic has 5 replies, 3 voices, and was last updated 6 years, 6 months ago by
- January 15, 2019 at 11:20 pm #43749
jinping.dai
ParticipantHello Everybody!
I am a newbie for wordpress and planning to use the shortcode for a submenu.
[wcfm_store_info id=”” data=”store_url”]
Is it possible to implement it like that? if possible, how and where to get the store ID quickly?
if not possible, at least i can use the direct url of each store, right?
if both are possible, which one is better for site performance (speed,migration etc.)
thanks in advance for any feedback!
- January 16, 2019 at 7:09 am #43819
“I am a newbie for wordpress and planning to use the shortcode for a submenu.”
– You want to add this submenu only for vendors, right?
- January 16, 2019 at 8:12 am #43833
Jinping
GuestNo. It’s not in specific vendor store. It is located in the header, as a sub menu or item of mega menu to nevigate all site visitors. It’s a multi items for all vendors.
- January 16, 2019 at 8:52 am #43845
Ok, understand.
Then [wcfm_store_info id=”” data=”store_url”] – this short code has no use here, it works fro specific vendor.
Tell me one thing, suppose you have 200 vendors, then all those will be added as submenu?
- January 16, 2019 at 8:57 am #43848
Jinping
GuestI use your plugin to setup my branch stores at different locations. Actually we have no more than 10 stores.
Please just tell me if I can use shirtcode as above.Different language will have different store in the main menu.
Or I can only use direct URL?
Thanks - January 16, 2019 at 9:35 am #43853
OK, I understand.
If you are dealing with fixed number of stores then it will be best to use direct URLs.
- The topic ‘How to get the store id for using it in short code’ is closed to new replies.
