How to Remove Notifications Order Filters
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How to Remove Notifications Order Filters
Viewing 3 reply threads
    • #65109
      Jack Cliff
      I would like to remove the notifications bar at the top and the order filters (All | Pending payment | Processing | On hold | Completed | Cancelled | Refunded | Failed).
      I have had a look in the php files and it is not clear. How would I go about doing this?
      Thanks 🙂
    • #65312
      Do you want to hide Dashboard Header or Header elements like, “Profile”, Notification, Knowledge Base etc … ?
    • #66149
      Jack Cliff
      Just notifications thanks 🙂
    • #66249
      If you are using WCFM Ultimate, then you may disable this easily from WCFM Capability setting.
      If, you are using only WCFM Free then please add this line to your child theme’s functions.php –
      add_filter( 'wcfm_is_allow_notifications', '__return_false' );
  • The topic ‘How to Remove Notifications Order Filters’ is closed to new replies.
