wcfm-santa
-362Day -16Hr -22Min -48Sec
wcfm-santa
How to Set a Default Product Description
Best Multi Vendor Marketplace Plugin for WordPress Forums Product Vendors How to Set a Default Product Description
Viewing 25 reply threads
    • #122986
      rohitxd
      Hey!
      I want to set default product description for vendor product entering page – description (not short description), How should I do it?
      Regards,
      Rohit
    • #122990
      rohitxd
      Ah Also
      2) How to make 2 registration forms like when u enter half of the information then in the next page the other info? can we make it?
    • #123375
      rohitxd
      reply pls
    • #123781
      rohitxd
      please help u guys not suportive
    • #123801
      >>Add this code in your theme’s functions.php
      add_filter('wcfm_marketplace_settings_fields_general', 'wcfm_marketplace_settings_fields_general_custom2704', 50, 2 );
      function wcfm_marketplace_settings_fields_general_custom2704($general_fields,$vendor_id) {
      	$store_product_description = wcfm_get_user_meta( $vendor_id, '_store_product_description', true );
      	if(isset($general_fields['gravatar']) ) {
      		$general_fields['store_product_description']= array('label' => __('Shop Product Description', 'wc-frontend-manager') , 'type' => 'wpeditor', 'class' => 'wcfm-textarea wcfm_custom_field_editor wcfm_ele wcfm_wpeditor', 'label_class' => 'wcfm_title', 'value' => $store_product_description );
      	return $general_fields;
      add_action( 'wcfm_wcfmmp_settings_update','fn_wcfm_vendor_settings_storetype_update2704', 50, 2);
      add_action( 'wcfm_vendor_settings_update','fn_wcfm_vendor_settings_storetype_update2704', 50, 2);
      function fn_wcfm_vendor_settings_storetype_update2704($user_id, $wcfm_settings_form ){
      	wcfm_update_user_meta( $user_id, '_store_product_description',  $wcfm_settings_form['store_product_description'] );
      Add the below script in your theme’s js file (https://developer.wordpress.org/reference/functions/wp_enqueue_script/)
      jQuery(document).ready(function ($) {
         $('#wcfm_store_setting_save_button, #wcfm_store_general_setting_save_button, #wcfm_store_address_setting_save_button').click(function(event) {
          event.preventDefault();
          var profile = getWCFMEditorContent( 'shop_description' );
            // WCFM Custom field Editor support
          if( $('.wcfm_custom_field_editor').length > 0 ) {
            $('.wcfm_custom_field_editor').each(function() {
              $wcfm_custom_field_editor = $(this);
              if( $wcfm_custom_field_editor.hasClass('rich_editor') || $wcfm_custom_field_editor.hasClass('wcfm_wpeditor') ) {
                $('#'+$wcfm_custom_field_editor.attr('id')).val(getWCFMEditorContent( $wcfm_custom_field_editor.attr('id') ));
          // Validations
          $('.wcfm-message').html('').removeClass('wcfm-error').removeClass('wcfm-success').slideUp();
          $wcfm_is_valid_form = true;
          $( document.body ).trigger( 'wcfm_form_validate', $('#wcfm_vendor_manage_store_setting_form') );
          $is_valid = $wcfm_is_valid_form;
          if($is_valid) {
            $('#wcfm_vendor_manage_store_setting_form').block({
              message: null,
              overlayCSS: {
                background: '#fff',
                opacity: 0.6
            var data = {
              action                    : 'wcfm_ajax_controller',
              controller                : 'wcfm-vendors-manage-marketplace-settings',
              wcfm_settings_form        : $('#wcfm_vendor_manage_store_setting_form').serialize(),
              profile                   : profile,
            $.post(wcfm_params.ajax_url, data, function(response) {
              if(response) {
                $response_json = $.parseJSON(response);
                if($response_json.status) {
                  wcfm_notification_sound.play();
                  $('#wcfm_vendor_manage_form_store_setting_expander .wcfm-message').html('<span class="wcicon-status-completed"></span>' + $response_json.message).addClass('wcfm-success').slideDown();
                } else {
                  $('#wcfm_vendor_manage_form_store_setting_expander .wcfm-message').html('<span class="wcicon-status-cancelled"></span>' + $response_json.message).addClass('wcfm-error').slideDown();
                $('#wcfm_vendor_manage_store_setting_form').unblock();
      Then you will find a field “Shop Product Description” in vendor settings. Here admin/vendor can add default product description.
      To show this field value in product page description section, you have to override description.php from “\wp-content\plugins\woocommerce\templates\single-product\tabs” to “yourtheme/woocommerce/single-product/tabs/description.php”.
      And this code to fetch default product description –
      <?php
      $product_id = get_the_ID();
      $vendor_id   = wcfm_get_vendor_id_by_post( $product_id );
      <p><?php echo wcfm_get_user_meta( $vendor_id, '_store_product_description', true );?></p>
      >>By default there is no possible setting option to achieve this.But this can be achievable by overriding registration template.
      Or if do you mean,”SUBSCRIBE TO MEMBERSHIP” section in this https://wclovers.com/knowledgebase/wcfm-membership/, then after activate “WCFM – WooCommerce Multivendor Membership” plugin use the Vendor membership page(which contain “[wcfm_vendor_membership]” shortcode) for vendor registration.
      Hope this information will help you.
    • #123854
      rohitxd
      Hi, Thank you so much for replying!
      1) I’ve done all steps as you said (the code stuff) but I cannot find where to set the default product description!?
      2) OK That’s fine 😀
      Regards,
      ROHIT
    • #124071
      You will find the “Shop Product Description” in WCFM store dashboard -> Store vendors -> Select vendor and go to store settings.
      If you still don’t find the field,then
      Can you please share me the screenshot where you have added the code?
      Or share us site details where we can check the code which you have added and the WCFM store dashboard.
      (Set as private reply)
    • #124099
      rohitxd
      Oh Thanks! I found “Shop Product Description” but will it work globally like every new seller should get that description when they add a product
      Thanks so much!
      ROHIT
      • #124104
        Yes you/admin (for each vendor)and vendor have to add “Shop Product Description”.
        I tried setting the “Shop Product Description” then I tried adding a product using my dummy seller account but It doesn’t show it while adding
        >>Do you override description.php from “\wp-content\plugins\woocommerce\templates\single-product\tabs” to “yourtheme/woocommerce/single-product/tabs/description.php” ? You have to add text “Shop Product Description” for your dummy seller account.
        • #124147
          rohitxd
          Yeah i did and also i added the code you said plus those both files look the same
    • #124101
      rohitxd
      Update: I tried setting the “Shop Product Description” then I tried adding a product using my dummy seller account but It doesn’t show it while adding :c
    • #124148
      rohitxd
      Ah I figured it Out thanks so much for the help dude you’re a god!
    • #124161
      rohitxd
      Ohhhh! btw How can we redirect sellers to there shop page when they login??
      AND
      Why can’t the seller edit the default product description while adding a product???
      Please help i need that
    • #124188
      >>When any seller/vendor register in your site it will took him store setup page/ thank you page. Vendor can click on “My Store” link in store dashboard will take him his store page.(PFA)
      >>Did you mean vendor can not edit their “Shop Product Description” field? It’s not depending on adding a product. Please check that you have added all codes which was previously mentioned and then recheck. IT’s working in our server.
    • #124410
      rohitxd
      1) OKAY!
      2) I want to add something like footer and it should appear in the product description so the seller can add there names in there and add the other stuff about the product
      How It should look while adding the product to the seller – https://prnt.sc/s7jm98
      How It should look in the product description – http://prnt.sc/s7jomg
      I want it to be appear in every new sellers product description like it should be a global product description that should come by default to every seller when there adding a product and they must be able customize it and add there own words…
    • #124747
      >> In “WordPress editor” we can add default a text (like this product owned by …) but it’s not possible to add this text at bottom of the editor. You/vendor have to enter the product content before/above this text.
      >>Your current requirement is totally different from the topic(I want to set default product description for vendor product entering page – description , How should I do it?) which you asked at the beginning. So which one will be your final requirement in product page front-end???
      Scenario 1:
      will it display like?
      <Product description>(from product edit dashboard)
      <product description default/footer text>(in product edit dashboard)(This product owned by ...)
      <Globally added shop description>(From vendor settings)
      Scenario 2:
      only the above two description and “Globally added shop description” this will be removed?
      Let us know.
    • #124995
      rohitxd
      No any way???
    • #125145
      You have to override the “wcfm-view-products-manage.php” from “\wp-content\plugins\wc-frontend-manager\views\products-manager” to your theme folder – “yourtheme folder/wcfm/products-manager/wcfm-view-products-manage.php”
      Then you have to modify the “description” variable with $description = '<br/><br/><br/><br/><br/>This Product is owned by [Type your Shop Name]'; where it is defined. (PFA)
    • #125322
      rohitxd
      I didn’t have a yourtheme folder/wcfm/products-manager/ wcfm-view-products-manage.php folder so I created a one added it, is that okay?
    • #125324
      rohitxd
      OMG Thanks man! You saved my life
      Appreciating the service you gave, Love it!
      BEST REGARDS,
      ROHIT
    • #125325
      You are always welcome 🙂
      We are closing this topic.
    • #125368
      rohitxd
      Ya Sure! Let me leave review for y’all!!
    • #127680
      rohitxd
      Hey I’ve got a problem!
      https://prnt.sc/sbtga1 – After adding the default description it doesn’t show some required fields
      I need the Shipping field and inventory field back please!
    • #127910
      >> Product Shipping field and inventory field not depends on product description, or previously mentioned code in this thread. You can check this removing all added code which was mentioned previously in this thread.(Before that make a backup).
      >>Check the vendor capability (WCFM store dashboard -> Capability), it’s turn-on or not.
    • #127948
      rohitxd
      Hello I’ve removed the code I previously added (the part inside the $desciption='(removedhere)’) and check and here is the result – https://prnt.sc/scgohv so the problem should be in that file so tried moving the folder i created “products-manager” to different location so it would detect it, and here is the result https://prnt.sc/scgpnf So that means the “wcfm-view-products-manage.php” have some problem, Please help also do you know how to remove this part https://prnt.sc/scgqgd
      BEST REGARDS,
      ROHIT
    • #127953
      Sorry, But it’s really confusing between your issue and requirement.
      You have to override the “wcfm-view-products-manage.php” and “wcfm-view-products-manage-tabs.php” from “\wp-content\plugins\wc-frontend-manager\views\products-manager” to your theme folder – “yourtheme folder/wcfm/products-manager/”
      and in “wcfm-view-products-manage.php” this file you have to add –$description = '<br/><br/><br/><br/><br/>This Product is owned by [Type your Shop Name]';
      display Shipping field and inventory field – did you check WCFM dashboard -> capability?And Groups Capability?
      To remove policy tab add this css in your theme’s style.css –
      div#wcfm_products_manage_form_policies_head {
          display: none !important;
    • #127957
      rohitxd
      >> This worked I didn’t add “wcfm-view-products-manage-tabs.php” to the folder thanks!
      >> Tried adding, but didn’t work
    • #127959
      rohitxd
      Ah Figured out
      Removing the div worked
      This code worked instead of that
