Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › I urgently need help
- This topic has 5 replies, 3 voices, and was last updated 5 years, 7 months ago by
- January 14, 2020 at 3:08 pm #102001
Auhouse.ru
ParticipantSellers cannot change the status of an order, add or update products. The page does not load after pressing the confirmation button, the page freezes and stands in one place. Help solve
Site Auhouse.ruAttachments:
You must be logged in to view attached files. - January 14, 2020 at 3:29 pm #102011
Auhouse.ru
ParticipantThe OneSignal plugin blocked the creation and updating of goods, but the order status is not updated, the page does not load
- January 14, 2020 at 3:34 pm #102015
SebastianFloKa
Participant… I’m user of WCFM as well, so I can’t help unfortunately. But I have almost the same issue and it looks like my ones related to pdf vouchers. Do you use pdf vouchers as well and does it occur when there’s a pdf voucher involved in the order?
And I could imagine WCLovers Support might be interested if this occured with the latest updates from weekend? - January 14, 2020 at 3:35 pm #102016
SebastianFloKa
Participant… slightly too late with my answer…
- January 14, 2020 at 3:40 pm #102018
Auhouse.ru
ParticipantI get errors on the order page when updating the status
You must be logged in to view attached files. - January 30, 2020 at 6:40 pm #104696
KeymasterHello,
It might be a plugin conflict issue. Can you check this in a clean environment i.e. with WooCommerce and WCFM plugins.
Let me know. Alternatively, you can share with me a temporary access here. Make sure you mark your reply private.
