Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Images not showing in vendor store side bar
- This topic has 9 replies, 3 voices, and was last updated 5 years, 12 months ago by
Sarmistha Chakraborty.
- February 11, 2020 at 11:19 pm #106743
gettingweduk
ParticipantI am using Zella theme and have featured items and new arrivals widgets in the vendor store sidebar. Products appear but the images are not there. Can you help please?
Thanks - February 19, 2020 at 1:46 pm #107772
Can you please share such a store url with me to check this once!
Between, are these widgets working perfectly in other pages?
- February 20, 2020 at 3:38 pm #108018
gettingweduk
ParticipantThis reply has been marked as private. - February 25, 2020 at 12:58 pm #108674
Kindly add this CSS to your site –
#wcfmmp-store ul.product_list_widget li img { position: relative !important; } #wcfmmp-store ul.product_list_widget li { padding-left: 5px !important; }Thank You
- February 25, 2020 at 3:28 pm #108708
gettingweduk
ParticipantThank you, that worked! The images are rather small though, is there any way of making these larger and perhaps the product titles smaller please? Please see the screenshot below:
- February 26, 2020 at 12:03 pm #108861
Try this CSS to your site –
.item-product-widget .product-meta .product-title { font-size: 90% !important; } .item-product-widget .images { padding-right: 0 !important; padding: 0 !important; } .item-product-widget.row.nasa-list-type-1 .images .nasa-product-widget-image-wrap{ width:100%; } #wcfmmp-store ul.product_list_widget li img { width:80px !important; height:80px !important; }Thanks.
- February 26, 2020 at 2:27 pm #108881
gettingweduk
ParticipantThank you, I have just added that code and it didn’t work unfortunately. I did change the font size from 90% to 40% to see if that made a difference but it didn’t.
Any help would be appreciated.
Thanks!- February 26, 2020 at 2:36 pm #108883
Where you have added the css? we don’t find any css was added in your site.
Please add above mentioned css in your activated theme’s style.css (<your site folder>/wp-content/themes/<your active theme>/style.css)Thanks.
- February 26, 2020 at 2:39 pm #108884
gettingweduk
ParticipantI’ve added it under Zella Theme Child: style.css, please see the screenshot.
- February 27, 2020 at 1:28 pm #109011
Kindly check once. The product images size are increase now.PFA
