Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Ultimate › Improvement recomendations
- This topic has 1 reply, 2 voices, and was last updated 6 years ago by
- February 17, 2019 at 8:43 pm #48636
FuBendu
Participant3 suggestions for improvement:
1 – Coupon codes: Vendors should not be allowed to use a code if it is already in use by another vendor. As currently is, when a vendor creates a coupon with a code that is already in use, the other code stops working.
2 – Followings – When a vendor is no longer active – deleted or disabled, the followings remain listed/active. Maybe when vendors have been deleted/disabled – data stored on the user side is also cleared or hidden.
3 – Offer vendors option to keep/put their store offline. When a new vendor joins the platform he might want some time to populate his site before going live. As is the vendor goes live immediately even if he has partial info/products – does not look good. Ideally, such functionality is added at yr level.
Thank you for the good work
b - February 18, 2019 at 4:51 pm #48776
Thanks, we will definitely take care of this in next update.
- The topic ‘Improvement recomendations’ is closed to new replies.
