Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Incorrect field reference
- This topic has 9 replies, 2 voices, and was last updated 6 years, 5 months ago by
- April 22, 2020 at 3:34 pm #121745
tgl
ParticipantWhen you change the “sold by label” from the default of “store” (in my case I changed it to “Sold by:”):
https://www.screencast.com/t/Uk5ugCw22SK
It also changes the word “Store” in three menu titles from “Store” to “Sold by:”:
https://www.screencast.com/t/TxhHh6ppziNJ
Store Hours turns into Sold by: Hours
Store Badges turns into Sold by: Badges
Store Verification turns into Sold by: Verification - April 22, 2020 at 8:50 pm #121901
Thanks for reporting this. We will fix that in our next update. - April 25, 2020 at 12:56 am #122700
tgl
ParticipantIt also changed one of the parent menus:
https://www.screencast.com/t/tnBkXNKZ5R
Store Vendors turns into Sold by: Vendors
- April 25, 2020 at 1:31 pm #122844
Kindly use the following snippet-add_filter( 'wcfmmp_sold_by_label', function($sold_by_label, $vendor_id) { if(is_wcfm_page()) { return __('Store', 'wc-multivendor-marketplace'); } return $sold_by_label; }, 10, 2);Add this code to your child theme’s functions.php
Let me know how this goes.
Thanks! - April 26, 2020 at 11:43 pm #123407
tgl
ParticipantIt also changed the name of every widget:
- April 27, 2020 at 4:19 pm #123653
The image you provided doesn’t show that. Every widget title seems fine there. Are you sure you sent me the right snapshot?
Looking forward to helping you. - April 27, 2020 at 10:21 pm #123817
tgl
ParticipantYou are 100% correct, I was just looking at the inline colon after looking at the others in the admin where I had “Sold by:”.
Sorry about that one!
- April 29, 2020 at 11:12 pm #124773
tgl
ParticipantHowever, I did just notice it changes the wording in the outgoing emails:
I assume this email is supposed to read “Notification – New Store” and not “Notification – New Sold by:”
- April 29, 2020 at 11:29 pm #124781
tgl
ParticipantWouldn’t it make much more sense to create a field that is just for use in the “Sold by” widget?
https://www.screencast.com/t/U2KmgRnYstQY
You list it in the admin as changing the wording in the widget yet clearly you attached it to a widely used WC field that is utilized in many locations.
- April 30, 2020 at 10:53 pm #125172
KeymasterHello,
I’ll pass this to my dev team to add a separate filter just to show the ‘Sold by’ label in the frontend. But, till then you can use this updated snippet. I believe this will not give you any unpleasant surprises.add_filter( 'wcfmmp_sold_by_label', function($sold_by_label, $vendor_id) { if ( ( ! is_admin() || defined( 'DOING_AJAX' ) ) && ! defined( 'DOING_CRON' ) && ! is_wcfm_page() ) { return $sold_by_label; } return __( 'Store', 'wc-multivendor-marketplace' ); }, 10, 2 );Please remove the previous code and replace with this new one.
Thank You!
- The topic ‘Incorrect field reference’ is closed to new replies.
