Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Delivery › Insert map into the checkout
- This topic has 7 replies, 3 voices, and was last updated 7 years ago by
- October 1, 2019 at 9:51 pm #84685
JESSICA88
ParticipantHello everyone,
Can you please guide me to add the short code of the map into the checkout please ?I
I’m not expert and try to manage my website.
I want to add only the map. Which is the short code ? [map””] ???
Well, when customer choose a store , it will reflected the store location map into the checkout.
Thank you.
By the way , when im trying to customise the store and put this short code on the page :
[wcfm_stores per row”3″]
It doesn’t affect the view
I have only 2 colum… 🙁
Why ?? - October 7, 2019 at 1:17 pm #85540
Mukakanga Konkola
ParticipantI need this too. I tried order tracking plugins but they do not properly integrate with WCFM. We need a response!
- October 10, 2019 at 10:13 pm #86104
Member[wcfm_stores per row”3″] – it’s wrong. It should be –
[wcfm_stores per_row="3"] - October 10, 2019 at 10:14 pm #86105
MemberDo you want to show vendor’s map at checkout or at customer’s order details page?
- October 12, 2019 at 2:17 am #86404
JESSICA88
Participanthello thanks for your reply,
[wcfm_stores per_row=”3″] it works ! THANK YOU
But for the map into the chechout customers details , if I use [wcfm_stores_map]
4 selections tab appear(location – category etc…. into the bottom) how can I remove that ?And it show the map with all stores but not the store affected by the order !
Thanks in advance
You must be logged in to view attached files. - October 12, 2019 at 1:39 pm #86497
– Well, it is not useful at checkout page.
What you want to show in checkout page using map?
- October 12, 2019 at 2:32 pm #86507
JESSICA88
I would like that when customer choose a product linked to a specific store and finish his purchase,
the customer should have into the checkout the map with the store selling this specific product.
Or if customer can received a mail or a link with the store position to go on site take away his product…Thank you
- October 14, 2019 at 12:10 pm #86782
Well, this will be possible using customization.
You may contact us here for this – https://wclovers.com/woocommerce-multivendor-customization/
- The topic ‘Insert map into the checkout’ is closed to new replies.
