Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Is Frontend Manager Required if you have ultimate?
- This topic has 1 reply, 2 voices, and was last updated 5 years, 6 months ago by
Sayan Naskar.
- April 20, 2020 at 12:29 pm #120868
splot.india
ParticipantI have WCFM Frontend manager & ultimate both installed, Is frontend manager still required even if you have ultimate? Problem is that because, i cannot update WCFM-Frontend manager, tried it many times but is throwing the same error.
Update Failed: <!DOCTYPE html> <!–[if lt IE 7]> <![endif]–> <!–[if IE 7]> <![endif]–> <!–[if IE 8]> <![endif]–> <!–[if gt IE 8]><!–> <!–<![endif]–> splot.in | 524: A timeout occurred <!–[if lt IE 9]><![endif]–> body{margin:0;padding:0} Error 524 Ray ID: 586ce88b0dedeb6d • 2020-04-20 06:48:08 UTC A timeout occurred <!– /.error-overview –> You Browser Working Los Angeles Cloudflare Working splot.in Host Error <!– /.status-display –> What happened? The origin web server timed out responding to this request. What can I do? If you’re a visitor of this website: Please try again in a few minutes. If you’re the owner of this website: The connection to the origin web server was made, but the origin web server timed out before responding. The likely cause is an overloaded background task, database or application, stressing the resources on your web server. To resolve, please work with your hosting provider or web development team to free up resources for your database or overloaded application. Additional troubleshooting information here. <!– /.section –> Cloudflare Ray ID: 586ce88b0dedeb6d • Your IP: 202.133.49.38 • Performance & security by Cloudflare <!– /.error-footer –> <!– /#cf-error-details –> <!– /#cf-wrapper –>
Other WCFM plugins and all the other plugins updated properly, only this wouldn’t update. Can you fix it please.
Thank You. - April 20, 2020 at 12:39 pm #120881
Sayan Naskar
Yes, the WCFM-Frontend manager is required even if you have ultimate as the ultimate add some features to the WCFM-Frontend manager.The issue you mentioned seems to be caused by your Cloudflare. Are you or your server is using Cloudfare CDN? You can try one thing manually downloading the WCFM-Frontend manager from the wordpress.org and uploading it to your server for the time being.
