Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Issue with Store page and header of my theme
- This topic has 14 replies, 2 voices, and was last updated 6 years, 3 months ago by
- April 1, 2019 at 5:28 pm #55623
Jose
I have changed my menu and I have left it so that when I scroll down, the logo must disappear.
It works well even on the store listing page, but when a specific store is displayed, it no longer works well.
I use Divi Theme, from elegant themes.
I wish I could be guided on how to fix this.Regards,
- April 1, 2019 at 5:29 pm #55624
Jose
ParticipantThis reply has been marked as private. - April 2, 2019 at 6:26 pm #55833
Can you please recheck this particular page setting! Possibly some theme setting not properly set as other pages.
There has no such CSS or property from WCFM to hide site log on scroll!
- April 3, 2019 at 12:18 pm #56018
Jose
ParticipantThis reply has been marked as private. - April 4, 2019 at 11:17 am #56133
Jose
ParticipantUpdate:
The issue with safe mode of divi theme on the wizard setup was resolved by Elegant themes with an update of Divi theme.
But more important that still the problem with scroll menu.
Regards,
- April 4, 2019 at 4:07 pm #56200
Well, this safe mode is only for testing purpose, right?
In live site in will be disabled! Then don’t worry about this.
- April 4, 2019 at 4:19 pm #56215
Jose
Yes, but was in live site the issue. But was an error from divi theme.
I understand what you tell me, but it is not possible to verify anything on a store page, since it is wcfm who creates that page.
Different is what happens with the page with the list of stores, that works perfect and allows you to hide the logo of my website with the scrolldown.
I can add that the same thing happens with the page for the dashboard, it has the same setting as the store list, but in this case it fails and does not hide the logo.Can you please re-check, because The only common are wcfm.
Regards,
- April 4, 2019 at 4:41 pm #56238
Jose
ParticipantThis reply has been marked as private. - April 4, 2019 at 11:05 pm #56273
Jose
ParticipantUpdate
Hi, I spoke with Elegant Themes support lead, they said:
It looks like some scripts are not loaded on the page and the header does not get an additional necessary class to hide the logo.
Can you try to contact wcfm multivendor marketplace support to report the issue so they can fix it? Also, I can check it more closely for you to see if there is anything I can do.I hipé with this can help to fix the issue.
Regards
- April 5, 2019 at 12:08 pm #56323
Jose
ParticipantThis reply has been marked as private. - April 6, 2019 at 8:58 am #56466
Now I am a bit confused in this topic!
You want to use a separate logo for setup widget, right?
Anything else you want to change?
- April 6, 2019 at 2:16 pm #56498
Jose
Don’t worry, I think that you confused topics, because here I ask you about that:https://wclovers.com/forums/topic/add-new-option-to-upload-other-logo-admin/
But the real topic here is about a report of issue with users with divi theme.
The support team of elegant theme told me a solution but by functions.php, I think that is a temporal solution, because you need add code to resolved issue with all divi theme users.
function custom_function(){ echo '<div id="main-content"><div class="container"><div id="content-area" class="clearfix"><div id="left-area"></div></div></div></div>'; } add_action('et_before_main_content','custom_function');
The real solution is add this code in your template.
Regards, and I hope help my report.
- April 7, 2019 at 3:46 pm #56671
– Think this will not work as functions.php only loads for site frontend, but store setup page is part of WP backend!
- April 7, 2019 at 4:17 pm #56689
Jose
ParticipantThis reply has been marked as private. - April 8, 2019 at 4:41 am #56740
MemberOK, that’s great.
Then possibly this theme loads functions.php at backend as well.
- The topic ‘Issue with Store page and header of my theme’ is closed to new replies.
