Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Javascript issues
- This topic has 16 replies, 5 voices, and was last updated 7 years, 10 months ago by
Shhiv Narayan.
- October 16, 2017 at 10:43 am #14408
dani1341
GuestHello,
I would like to request for the annoying
//Comments
to be removed from all the javascript files,
as when using either Autoptimize or WP Fastest Cache to minify Javascript it just completely breaks the plugin (both the free and ultimate version).My website is really javascript heavy and things like this are unacceptable (having to manually remove them each update is annoying).
I would be really grateful if they were removed.
Thanks - October 16, 2017 at 11:30 am #14409
WCfM Forum
I am really very sorry for such inconveniences, this is no way acceptable.
We will definitely fix all these by next update, even we are goong to use minified script for WCfM very soon.
Can you please tell us which are the plugins you are using in for caching then we will specifically test with them.
Autoptimize has no issues as all our demos run with this and nothing breaks.
- October 16, 2017 at 12:37 pm #14426
dani1341
GuestHi, just selecting in “Autoptimze” the option “Optimize JavaScript Code?” breaks most of the functions (adding products, seeing products in products page and even the settings page is all messed up.
I have tried “WP Fastest Cache” instead of “Autoptimize” and it still breaks the same functions. - October 16, 2017 at 6:08 pm #14430
WCfM Forum
We are just looking into this.
Script minification causes some issues, we will handle this in new version be sure.
Really sorry for such inconvenience.
- October 17, 2017 at 11:48 pm #14506
WCFM 3.2.2 has just released and we have added exclusive support for WP cache and minify plugins.
Be sure, you have to purge existing cache and JS/CSS minification after updating the plugin.
- October 18, 2017 at 8:48 am #14520
dani1341
GuestHello, i would like to report that even after the update there are still issues with javascript (when adding a product).
I checked wcfmu-script-products-manage.js and there are still //Comments inside it which breaks when minified (the first one i saw), it seems most of the issues are resolved but it still breaks due to the added //Comments within all of the javascript files.Im sorry if im annoying and thanks.
- October 18, 2017 at 9:10 am #14525
Shhiv Narayan
No way of annoying!!
We have tested the plugins with Autoptimize, WP Fatest Cache, WP Super Cache, High Velocity Minifier and many other plugins as well.
Those comments are not all issue for minification.
Between, currently which caching or minifier plugin you are using in?
Hope you have purge opd cache and js/css minifies?
Can you please take a look into Google Chrome Incognito mode, may be some browser caching is there!!
And please tell me the plugin name, I will check that again.
Really sorry for the repeating the same trouble.
Shhiv
- October 18, 2017 at 9:27 am #14527
dani1341
GuestIm using Autoptimize
https://de.wordpress.org/plugins/autoptimize/A3 Lazy Load
https://de.wordpress.org/plugins/a3-lazy-load/Im using WC Frontend Manager + WC Frontend Manager Ultimate + WC Vendors + WC Vendors Pro
The settings i want to use in autoptimize
https://puu.sh/y0ZBq.JPGBefore activation of javascript minification from autoptimize
https://puu.sh/y0ZBk.JPG
https://puu.sh/y0ZBh.JPGAnd after activation of javascript minification from autoptimize
https://puu.sh/y0ZBn.JPG
https://puu.sh/y0ZBf.JPGBrowser used Firefox (latest version) with cache disabled.
- October 18, 2017 at 9:33 am #14528
Shhiv Narayan
MemberReally thanks for such detailed info, we are checking with the same setup.
We didn’t check with A3 Lazy Load even!!
Thanks for your cooperation.
- October 18, 2017 at 4:41 pm #14532
Shhiv Narayan
Can you please send me one more screenshot please!!
When you are getting such page – https://puu.sh/y0ZBn.JPG
I want to check browser console errors.Easiest way to get this – Open the site in Google chrome and press F12 and you will have browser console, hope you already know about this.
Actually I have setup the things and getting a error from Autoptimize for “Force JavaScript in
?” this settings but that error is not from WCFM scripts, so I want to verify are you getting same error or something different!!Thanks for all your cooperation.
Shhiv
- October 19, 2017 at 8:21 pm #14566
dani1341
GuestThis reply has been marked as private. - October 20, 2017 at 5:07 am #14580
MemberAhh … that will be really great.
- October 22, 2017 at 3:11 pm #14713
WC Lovers Forum
We are waiting for your response and staging access.
- October 24, 2017 at 9:08 am #14747
sylvia
ParticipantThis reply has been marked as private. - October 24, 2017 at 9:26 am #14748
WCfM Forum
Really thanks for that.
I am just looking into the issues righ now.
Shhiv
- October 25, 2017 at 6:56 pm #14826
Shhiv Narayan
I have debugged into the issue and this is not for WCFM scripts or any comment within Javascript files.
Can you please contact us at mail, I want to show you snap and if you can tell me from which plugin those are loading?
Even I found that your site “contact us” broken and reason is same.
Between, all these only because of “Force JavaScript in
?” this option from “Autoptimize”, actually most of the scripts can’t work from head. This also break Javascript inter-dependencies, best is to avoid this for large sites, specially when you have too many plugins and lots of Javascript files.Please contact me at wclovers.contact@gmail.com or submit here https://wclovers.com/contact-us/
Shhiv - October 26, 2017 at 7:55 pm #14873
Shhiv Narayan
MemberI am closing this topic as this issue is not from any WCFM JS, rather it’s configuration mismatch.
WCFM has no issues with “Autoptimize” and “A3 Lazy Loading”
Thanks for your patience.
- The topic ‘Javascript issues’ is closed to new replies.
