Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › js conflicts
- This topic has 33 replies, 5 voices, and was last updated 7 years, 12 months ago by
- September 3, 2017 at 11:56 pm #12838
support1
ParticipantHi again.
Installed ultimate to access Downloadable products.
The odd js and display issue remains please see here re violation noticesNote deactivated plugins but still get this when attempting front end product editing.
Opening the product results in the having Product Specs loaded with tabs active until you click on all of them.
It appears to be an “order” of operation or sync issue. - September 3, 2017 at 11:57 pm #12839
support1
ParticipantThis reply has been marked as private. - September 4, 2017 at 5:11 am #12843
Shhiv Narayan
Really sorry for the inconvenience!!
This is totally from WCFM FREE so WCFM Ultimate deactivation will not resolve anything.
There are always some strange issues arise in your site, I think there has some conflicts with your theme.
Can you please tell me the Theme you are using in.As you know this is not a normal issue, none of our demos has such problem.
One more thing, can you please check the things by any default WP theme or Store front – are you experiencing same or not?Thank You
- September 4, 2017 at 5:55 am #12844
support1
ParticipantThis reply has been marked as private. - September 4, 2017 at 5:56 am #12846
support1
ParticipantThis reply has been marked as private. - September 4, 2017 at 7:13 am #12847
Shhiv Narayan
Yeah right, that popup has some issues.
We will replace that with something more stable in WCFM next version.Also looking into the Product Manager issue as well.
Are you experience the same in Product Manager using default theme ?
- September 4, 2017 at 7:20 am #12848
support1
ParticipantThanks – the product issue is intermittent with 2017 but it is there sometimes which makes me think it is some sort of timing or loading issue 🙂
Thanks so much for your great support and great plugin. - September 4, 2017 at 7:21 am #12849
support1
ParticipantJust to be clear I mean the WP theme TwentySeventeen
- September 4, 2017 at 8:54 am #12851
WCfM Forum
GuestWell, thanks.
We are also looking into this and be sure fix by our next update.
WCfM next update willl come by tomorrow.
Thanks for cooperation.
- September 4, 2017 at 4:01 pm #12857
Shhiv Narayan
I have just checked your site and currently WP default theme activated so there is no such issues in Product Manager Accordion.
Kindly activate your actual theme so that I can check the issue.
- September 4, 2017 at 8:30 pm #12868
Shhiv Narayan
WCfM 3.0.3 has just released.
We have replaced quick edit popup with fancy box.
Kindly update yours and check are still getting such issues or not!!
- September 5, 2017 at 3:25 am #12871
support1
ParticipantThanks so much again.
I have updated – cleared cache however still see the same violation notice re popup/
and the odd outlay for group on product attributes.
Also please see now the categories (we need hundreds of them so not sure what to do here :))
I have no cache installed on the site itself. - September 5, 2017 at 4:30 am #12872
wwestonh
ParticipantI am also seeing a strange/different layout for my product attributes group here:
https://www.evernote.com/l/AS5ILxWNmxlKaaqoy9PBE23jQsQE6Qpy7GU
Image uploading has also broken for my test user:
https://www.evernote.com/l/AS6TcQ4CjjJAM6kEBjmr_mShx5UuLGTvNHk
- September 5, 2017 at 8:06 am #12881
Shhiv Narayan
We have just changed product category and tag association options to the right sidebar as WC default product in wp-admin.
Is this not good for you?
Are you comfortable with the previous layout??Please check in your Multi-vendor plugin’s capability Settings – it’s blocking Vendors media upload ability.
Or if you have any other user role editor plugin then please check Settings once.
- September 5, 2017 at 10:44 pm #12936
support1
ParticipantHi again..
If you could look at the layout when you have time, I think for those of us who have many product categories, the option on the sidebar may not be practical as is makes the product scroll very very long. Unless maybe they could accordion so they are neat and one line per category rather than dozens?The violation notice remains and shows “ultimate”
Also product pictures – multiple appears to only allow a single upload at a time (cannot click 6 to create the product view have to click each of the 6 pictures and add individually)
Is this intended behaviour?
Also when attempting to add a gallery to the product
media-editor.min.js:1 Uncaught TypeError: Cannot read property ‘value’ of null
at Object.insert (media-editor.min.js:1)
at Array.<anonymous> (media-editor.min.js:1)
at i (jquery.js:2)
at Object.add [as done] ( - September 6, 2017 at 3:04 am #12937
wwestonh
ParticipantWhen I reverted back to version 2.6.2 (for both WCFM + WCFMU) the attributes dropdown select menus are once again working in my main product view:
https://www.evernote.com/l/AS74eYm-M45DLLgdS7uWcylmG85Cw4-Vtxg
If these dropdown attributes would preload correctly, the right-hand column layout for the attributes selects would be fine in 3.0.3
- September 6, 2017 at 5:09 am #12938
We have make this changes as many users ask to have same kind of Category widget as they have in wp-admin panel.
Actually, that selector type widget has a big draw back – suppose you have more than one same name sub-categories and search for that then will have list of all those. Now how you can identify which sub-category belongs to which main-category.Just to mention, in our next version we are going to have this optional, you may choose wither widget type.
Off course, there was an JS issue, It comes whenever you uploads a image. Will be also fix in next version.
But it will not possible to set more that one image at the same time. In fact in version it will not possible to choose more one image at a time.Thank You
- September 6, 2017 at 5:36 am #12946
wwestonh
ParticipantOk — so you are saying that it is your intended functionality for these Attribute dropdowns as defined here:
https://www.evernote.com/l/AS5-VAIW9dZDaqAePKYD-i5H9Mna01TQZ6A
To no longer populate the dropdowns in WPFM 3.0 here:
As they did in 2.6 here?
- September 6, 2017 at 6:05 am #12947
support1
ParticipantThe categories will be an issue as we have many (note you are dealing with more than one user on this thread) we have 12 categories and growing currently shows a huge long list.
More than one image – this is what happens in WP admin – we can choose the 6 images at once and they load to the product.
Is there a workaround as almost all of our products require 6 separate images.? - September 6, 2017 at 6:07 am #12948
Shhiv Narayan
No, we are talking about Product Category Widget.
Attributes no way should be there, it has separate box (below the screen)
If you are getting Brand Attribute right side widget then it’s a bug. Can you please show us Brand Attribute edit screen snap please!!
In WCfM 2.6.2 you also have those same widgets under Category selector, element wise no changes only position replaced.
- September 6, 2017 at 7:29 am #12949
Shhiv Narayan
MemberAhh … Thanks for mentioning this.
I assume you both are from same team.Well, we have decided to use colapsables format for Category widget. So that sub-categories will be hidden and only main categories visible. Hope this will helpful for long set of categories.
WCfM will going to use a different media uploader very soon. Then multiple upload will not an issue, please bare for some time with this solution.
We are looking into the Attributes issue as well, if it’s showing there then it’s a serious bug.
- September 6, 2017 at 9:51 pm #13023
Shhiv Narayan
WCfM 3.0.4 has just released.
Kindly update yours and check.
Attributes issue resolved.
Category view upgraded, check the documentation here –
http://wclovers.com/knowledgebase/wcfm-category-multi-view/Thanks for your patience.
- September 7, 2017 at 3:03 am #13045
wwestonh
ParticipantAwesome thanks for this! As you can see WCMp shows all product Attributes under Categories & Tags with the dropdown selects:
https://www.evernote.com/l/AS7EdOSRyM1BG797kNom8ZsAu_mX-IwVFxg
In 2.6.2 all of these Attribute dropdowns were showing as well:
https://www.evernote.com/l/AS7sM1C8PEhNDK2N7uljaG5Yn5NXqdJWLKg
Is it possible to bring this back to 3.0.x?
- September 7, 2017 at 1:49 am #13042
support1
ParticipantThis reply has been marked as private. - September 7, 2017 at 1:50 am #13044
support1
ParticipantNoting that issue is in “edit mode”
When adding a new product the flat categories are as expected. - September 7, 2017 at 5:52 am #13058
As per your screenshot you have “Disabled” category checklist view so things are coming as Flat View.
Please change the settings.Toolset Category -I have to check this. But If you have created any additional Product Taxonomy then those will be visible. In your site I already seen two additional Product Taxonomies – “Resource Type” & “Resource Label”.
- September 7, 2017 at 11:28 am #13060
Shhiv Narayan
MemberHi @wwestonh,
Attributes issue has been resolved in WCfM 3.0.4
- September 7, 2017 at 1:27 pm #13061
wwestonh
ParticipantWhen I upgraded to 3.0.4 the Attributes dropdowns are still missing from the main product section:
https://www.evernote.com/l/AS7bUQ1COBlF_6XZSyshL0UcDZWMOk7GYi4
- September 7, 2017 at 1:41 pm #13062
wwestonh
ParticipantHere is where the Attributes dropdowns were showing in 2.6.2:
https://www.evernote.com/l/AS7zE9rISwFF7Y_pd-Q8t6h7Q6PthhCHURc
- September 7, 2017 at 2:56 pm #13065
Shhiv Narayan
That was a bug.
Attributes should be under Attributes tab.
We have fixed that in 3.0.4 version.If you want something like those then why not going for Product Custom Taxonomy?
- September 7, 2017 at 3:23 pm #13068
wwestonh
ParticipantBut under the Attributes tab we will need to add each individually and, after a specific Attribute is added, there is no pre-populated dropdown list:
https://www.evernote.com/l/AS5-c_8r_JxB7aXaqKqJelnBBzE6b4eQmb0
Is it possible to have all the attributes expanded here (as WCMp and 2.6.2 had them laid-out)?
- September 7, 2017 at 5:58 pm #13070
WCfM Forum
I understand your concern but WooCommerce works in this way, you may check in wp-admin panel as well.
You may get attributes as dropdown list but then you have to define Attributes as “Dropdown” type. But I have checked screenshots you have defined those as “Text”.
Can you please share with us what is your purpose of this? Why you are not using custom taxonomy ?
If you really want to go with Attributes then please define those as Dropdown.
WCfM front-end product manager behave exactly same as WooCommerce backend product manager.
Please know your thoughts.
- September 8, 2017 at 4:23 pm #13092
Weston Happ
GuestThis reply has been marked as private. - September 8, 2017 at 4:43 pm #13094
Please go through this, you will understand that –
https://docs.woocommerce.com/document/managing-product-taxonomies/This was a bug.
We know that, WCMp Product Manager has the same issue. Hopefully they will also fix that by next update.
You have to set Attribute Type “Select” then you can choose attributes from selector-dropdown.
But as you have Attributes Type “Text” so they come as normal Textarea and ask for “|” separated value.Now WCFM front-end product manager behaving exactly like WooCommerce backend product manager.
Your password reset system is not working – really sorry for that, will look into this soon.
- The topic ‘js conflicts’ is closed to new replies.
