Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Layout problem with WC Bookings
- This topic has 9 replies, 3 voices, and was last updated 7 years, 10 months ago by
- October 18, 2017 at 7:42 pm #14536
mariechausse83
ParticipantWhen I modify a product, the layout is completely all over the places https://www.bloomnature.com/tableau-de-bord-bloomer-vendeur/wcfm-products-manage/1932/. Also, how can we select virtual for bookable products. Thank you for your help. M
- October 18, 2017 at 7:54 pm #14537
Can you please show me screenshot of that, I can’t access WCFM any pages without login!!
Virtual is option part of WCFM Ultimate, if you already have that installed then it’s showing just beside product type box.
One more very important thing, if you are using any caching or JS/CSS minifier plugin then please purge old cache/minifies and take a look.4
Shhiv - October 18, 2017 at 8:04 pm #14541
mariechausse83
ParticipantThank for your answer. Unfortunately,purging url did not change a thing and virtual product do not appear for booking eventhough I have the latest version of ultimate.
You must be logged in to view attached files. - October 18, 2017 at 8:12 pm #14543
WCfM Forum
Regarding Virtual option –
If you are checking this as Vendor login then kindly take a look as Admin login, are you getting this or not?
If you have this option as admin then kindly go to vendor capability settings, it’s definitely disabled!!
I am looking into this layout issue.
Really sorry for such troubles.
- October 18, 2017 at 11:31 pm #14545
mariechausse83
ParticipantThis reply has been marked as private. - October 19, 2017 at 5:20 am #14558
WCfM Forum
If you can give me that it will be great.
I can easily debug the things!Thank You
- October 19, 2017 at 5:24 am #14559
mariechausse83
ParticipantThis reply has been marked as private. - October 19, 2017 at 5:33 am #14561
mariechausse83
ParticipantThis reply has been marked as private. - October 19, 2017 at 5:55 am #14563
WCfM Forum
GuestThank You very much.
I am just looking into this.
- October 20, 2017 at 5:20 am #14582
I am sorry a bit delayed reply.
I have debug the things in your site and found that it’s just WooCommerce Bookings plugin’s version issue.
WCFM required atleast 1.10.7 to run as WC Booking added many new features in this version.
Please upgrade yours and take a look.
- The topic ‘Layout problem with WC Bookings’ is closed to new replies.
