Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Links in sidebar menu is not working in seller account
- This topic has 5 replies, 2 voices, and was last updated 7 years, 10 months ago by
- June 10, 2018 at 4:42 pm #24634
Majd Alkouifi
All the links in seller account page navigate me to only seller management page for example if I click on product, settings, followers or whatever is it redirect me to seller management page which is the home page for the seller account!
Any recommendation how to fix this?
- June 10, 2018 at 6:56 pm #24642
Can you please check and be sure one thing, WCfM dashboard page properly set under setting.
Check this at wp-admin -> WCfM Options (probably last menu option at left)
- June 10, 2018 at 7:53 pm #24645
Majd Alkouifi
After tons of tries, I figure out these points:
1- I’m using Dokan Lite plugin.
2- I’m using WPML for translating.
3- Ma main language is Arabic.What I’m facing:
When the customer order more than one item from a different seller and they click on a place order button (Arabic Langauge) the thank you page changed to the English Language automatically and it says that this order have products from different sellers so we split your order to more than one order, this thing from Dokan plugin and I’m fine with it but why the language changed to English! So I go through WPML settings and I found an option for that “Translatable – use translation if available or fallback to default language” when I activate it the problem solved! But when my seller access his seller management page none of the endpoints work so I disable that option from WPMl and now is working but now the old problem for multi-vendor order back again and when someone order from a different seller in the Arabic language after they place the order the language changed to English!
This issue really pissed me off. Any help, please? - June 10, 2018 at 9:36 pm #24652
I understand the problem bu it’s difficult to suggest a solution for this.
As you know WPML systems are quite complex and we have to debug this a bit.
Now we can debug this in two way.
If you are comfortable then share your site access with us. (Share only form here – https://wclovers.com/contact-us/)
Otherwise, we can arrange a TeamViewer session to do the same in front of you.
Please know me your preferable option.
- June 11, 2018 at 7:38 pm #24700
Majd Alkouifi
Thank you for your reply, I already share the site details.
- June 12, 2018 at 12:09 pm #24725
Thanks for that, we already received those.
Our team is looking into this.
Thanks for your cooperation.
- The topic ‘Links in sidebar menu is not working in seller account’ is closed to new replies.
