Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM Marketplace – REST API › Login Failure Contact Admin-Probable Cause Incorrect url
- This topic has 4 replies, 2 voices, and was last updated 6 years, 9 months ago by
tradeshamim.
- November 30, 2019 at 11:19 pm #95099
tradeshamim
I just installed WCFM Marketplace – REST API, JWT Authentication for WP REST API and configured htaccess and wp- config in the manner suggested. screenshot attachedDownloaded and Installed WCFM app on android. But cannot login as vendor, showing the “Login Failure Contact Admin-Probable Cause Incorrect url” error message.
I might have made some mistake.Could you help
You must be logged in to view attached files. - November 30, 2019 at 11:53 pm #95107
Sayan Naskar
Can you please chech if you are entering the site url with http:// or https:// which depends on your site.
Send us your site link we will tell you what you need to enter as the site url.Thank you.
- December 2, 2019 at 12:01 am #95378
tradeshamim
ParticipantThis reply has been marked as private. - December 2, 2019 at 12:12 am #95384
Sayan Naskar
This is strange and should not happen. Can you provide a temporary vendor access and a temporary admin access of the site for us to check?
Please send the access through the contact form in our site https://wclovers.com/priority-supportRegards,
- December 2, 2019 at 6:58 pm #95594
tradeshamim
ParticipantHi Sayan,
Thanks for your response. I was able to login after uninstalling and fresh installation of the app.
However, I couldn’t figure out a way to upload product picture while adding product, is there a way to do so? Or Users can only add product name and price?
Whatever may be, thanks for developing such a nice plugin. Best wishes.
- The topic ‘Login Failure Contact Admin-Probable Cause Incorrect url’ is closed to new replies.
