Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Logout Redirection
- This topic has 13 replies, 3 voices, and was last updated 6 years, 3 months ago by
- April 29, 2020 at 5:31 pm #124652
eguareone
ParticipantHi Friends,
Please how do I redirect vendors to a custom URL when they log out from the frontend manager? I found some tips online but none worked… Any help will be appreciated. Thanks.
- April 29, 2020 at 7:13 pm #124689
Please use the following snippet for your requirement-add_filter( 'wcfm_logout_url', function( $logout_url ) { if( wcfm_is_vendor() ) { return 'URL_YOU_WANT_TO_GET_REDIRECTED_TO'; // set your url here } return $logout_url; }); add_filter('woocommerce_get_endpoint_url', function($url, $endpoint, $value, $permalink) { if($permalink === 'URL_YOU_WANT_TO_GET_REDIRECTED_TO') { // repeat the same url return $permalink; } return $url; }, 10, 4);Add this code to your child theme’s functions.php
Let me know how this goes.
Thanks! - May 1, 2020 at 2:18 am #125215
eguareone
ParticipantHi thanks so much for your reply.
I’m not to clear on where to place the custom url on the code
Below is how i understand it. Custom url is https://abaaexpress.com.ng/seller-login
add_filter( 'wcfm_logout_url', function( $logout_url ) { if( wcfm_is_vendor() ) { return 'https://abaaexpress.com.ng/seller-login'; // set your url here } return $logout_url; }); add_filter('woocommerce_get_endpoint_url', function($url, $endpoint, $value, $permalink) { if($permalink === 'https://abaaexpress.com.ng/seller-login') { // repeat the same url return $permalink; } return $url; }, 10, 4);Did I do it right?
Thanks again for your help.
- May 1, 2020 at 3:29 am #125225
eguareone
ParticipantNever Mind, It worked but when it logs out it shows an incomplete site and changes the url to https://abaaexpress.com.ng/seller-login/?_wpnonce=fcd103599e instead of https://abaaexpress.com.ng/seller-login/
Is this normal?
- May 1, 2020 at 8:48 pm #125468
KeymasterSorry! The code wasn’t working. It was redirecting you to that page and not logging you out. Here is the updated code-
add_filter( 'wcfm_logout_url', function( $logout_url ) { if ( wcfm_is_vendor() ) { return 'https://abaaexpress.com.ng/seller-login/'; } return $logout_url; } ); add_filter( 'woocommerce_get_endpoint_url', function($url, $endpoint, $value, $permalink) { if ( $permalink === 'https://abaaexpress.com.ng/seller-login/' ) { return add_query_arg( 'wcfm_logout', 'yes', $permalink ); } return $url; }, 10, 4 ); function redirect_page() { global $wp; if ( ! empty( $_REQUEST['wcfm_logout'] ) && ! empty( $_REQUEST['_wpnonce'] ) && wp_verify_nonce( sanitize_key( $_REQUEST['_wpnonce'] ), 'customer-logout' ) ) { wp_safe_redirect( str_replace( '&', '&', wp_logout_url( esc_url_raw( 'https://abaaexpress.com.ng/seller-login/' ) ) ) ); exit; } } add_action( 'template_redirect', 'redirect_page' );This should be a one line code but due to a known bug in WooCommerce, we have to take this ugly route!
Let me know how it goes.
Thank You! - May 2, 2020 at 8:43 pm #125763
eguareone
ParticipantThank you for this! I’m afraid that this new code did not work. It gave the following error
Something went wrong. Your change may not have been saved. Please try again. There is also a chance that you may need to manually fix and upload the file over FTP.
Please is there an alternative? I don’t want to use FTP
- May 3, 2020 at 5:18 pm #126076
KeymasterHello,
It’s not a good idea to edit anything without ftp. If anything goes wrong, like a fatal error, then you can’t recover it from frontend.
To add snippets from wp-admin, use this plugin – https://wordpress.org/plugins/code-snippets/. It’s much better than editing theme’s functions.php using theme editor option.
Finally, the error you are seeing, is not related to the code. If possible use the plugin I mentioned or ftp.
Thanks! - May 7, 2020 at 11:22 am #127874
eguareone
ParticipantHello Sushobhan
Thanks for the heads up and all your help so far. I finally tried the code, The logout redirection worked but not as you expected it to. When the vendor logs out from Store Manager, It gives them a prompt, something like “Do You really want to logout from “Website Url”? On confirmation, it redirects to the wordpress admin Login Url instead of the abaaexpress.com.ng/seller-login/Please I really need help with this as i’m not good with codes. Thanks again
- May 7, 2020 at 12:27 pm #127898
KeymasterIt should work without the confirmation. I have again tested it on my local setup. Please check if you have pasted the complete code or not. Where you are pasting the code in functions.php or using the snippet plugin? Please send me a snapshot of the portion of the code.
Alternatively, could you please provide me a temporary ftp along with a vendor access to debug this?
Thank You! - May 8, 2020 at 3:03 am #128180
eguareone
I prefer the alternate measure. Please send me an email to abaaexpress@gmail.com so that I can forward the FTP and Vendor Login Access. Thanks
- June 29, 2020 at 6:58 pm #145028
server.monks123
I also tried the code, The logout redirection worked but wen the vendor logs out from Store Manager, It gives them a prompt, something like “Do You really want to logout from “Website Url”? On confirmation, it redirects to the wordpress admin Login Url instead of the https://inditribes.co.in
Please help me outAttachments:
You must be logged in to view attached files. - July 2, 2020 at 7:48 pm #145718
Could you please send me the code snippet that you are using?
Thanks! - July 2, 2020 at 10:21 pm #145770
server.monks123
Participantadd_filter( ‘wcfm_logout_url’, function( $logout_url ) {
return ‘https://inditribes.co.in/’;
return $logout_url;
add_filter( ‘woocommerce_get_endpoint_url’, function($url, $endpoint, $value, $permalink) {
if ( $permalink === ‘https://inditribes.co.in/’ ) {
return add_query_arg( ‘wcfm_logout’, ‘yes’, $permalink );
return $url;
}, 10, 4 );
global $wp;
if ( ! empty( $_REQUEST[‘wcfm_logout’] ) && ! empty( $_REQUEST[‘_wpnonce’] ) && wp_verify_nonce( sanitize_key( $_REQUEST[‘_wpnonce’] ), ‘customer-logout’ ) ) {
wp_safe_redirect( str_replace( ‘&’, ‘&’, wp_logout_url( esc_url_raw( ‘https://inditribes.co.in/’ ) ) ) );
exit;
add_action( ‘template_redirect’, ‘redirect_page’ ); - July 4, 2020 at 8:54 pm #146104
The code seems correct. Not sure why it is behaving unexpectedly!
Would you be comfortable sharing temporary backend access to your site, to debug this further?
When sharing the access, please don’t forget to mark the reply as private.
- The topic ‘Logout Redirection’ is closed to new replies.
