Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Lots of Errors and Bugs
- This topic has 1 reply, 2 voices, and was last updated 6 years, 9 months ago by
- September 8, 2019 at 4:57 am #80691
basvanam
I just started using this plugin because I have to build a website for a client of mine. The thing is, there are A LOT of bugs I came across already..
The 2 main bugs I spot now are:All the input selection fields are stripes, so it’s very hard to click on the little square boxes to check it on or off because it appears as a vertical stripe..
This is with ALL the selection square boxes. (See image)Second of all, when I try to add a new article to my store as a test, the submit button isn’t responding.. You can click on it but nothing happens.. It’s like there is no action or link or anything to it. This makes it of course impossible to add any products…
You must be logged in to view attached files. - September 9, 2019 at 11:13 am #80786
I am really sorry for the trouble. But I think you are having these issues either due to theme or some other plugins.
You may check our demo and there has no such issues – https://wcfmmp.wcfmdemos.com/my-account/
– I am pretty sure your site has JavaScript errors. Please check in Google Chrome Browser console, is there any JavaScript error happening to the site or not!
Between, theme you are using for the site?
- The topic ‘Lots of Errors and Bugs’ is closed to new replies.
