Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Mandatory Attribute Visible on Product Page
Tagged: mandatory, product page, show attribute, vendor
- This topic has 4 replies, 3 voices, and was last updated 6 years, 5 months ago by
- April 7, 2020 at 1:09 am #116079
contatoapp
ParticipantThe vendor option for the attribute to be shown on the product page is not mandatory. How can I make it so?
- April 9, 2020 at 9:45 pm #117369
contatoapp
ParticipantHi. Does anyone have a solution for this? Thanks.
- April 12, 2020 at 12:29 pm #118327
All attributes or only some specific one?
Between, when vendors add products “Show on Product” page option by default comes with “check”. Now if vendor disabled that then it’s his/her choice.
- April 12, 2020 at 10:44 pm #118512
contatoapp
ParticipantHi. What I meant is that the “Show on product page” option should be mandatory so vendors are required to check it. So all the product attributes are always shown.
- April 13, 2020 at 8:55 pm #118797
Kindly use the following snippet for this purpose-add_action( 'after_wcfm_products_manage', function() { ?> <script> jQuery(document).ready(function($) { if($('#attributes').length) { $('#attributes').on('click', '[id^="attributes_is_active_"],[id^="attributes_is_visible_"]', function() { $(this).closest('.wcfm_attributes_blocks').find('[id^="attributes_is_active_"],[id^="attributes_is_visible_"]').prop('checked', this.checked); }); } }); </script> <?php } );Add this code to your child theme’s functions.php
- The topic ‘Mandatory Attribute Visible on Product Page’ is closed to new replies.
