Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Mandatory fields in product edit screen
- This topic has 5 replies, 4 voices, and was last updated 6 years, 4 months ago by
- October 24, 2019 at 1:02 pm #88786
Zeljo
I would like to make the price mandatory in the product edit screen, is this possible? What I want to do is to remove the ability for someone to add free products.
- November 2, 2019 at 3:14 pm #90284
Zeljo
ParticipantNo support for paid plugin? Where can I get my money back?
- November 2, 2019 at 5:13 pm #90303
sdel_nevo
I beleave you can set this in the product custom validation area in the settings section
Not sure if that’s enabled with WCFM Ultimate or the groups and staff plugin to be honest, I’ve got both and can’t remember which one had this capability,
Steve
- November 5, 2019 at 5:50 pm #90811
– Yeah right, you may set this from WCFM Admin Setting -> Product Custom Validation – https://ibb.co/XxxC7brThank You
- November 9, 2019 at 1:36 am #91487
Zeljo
ParticipantThis does not work, I’ve checked the validation for the price, but it still does not validate it. But, it doesn’t matter, because due to the integration with WooCommerce Booking, I need to make the _wc_booking_block_cost mandatory. This is the Block cost, and I need to validate this, how can this be done? IS there a filter for this?
- November 9, 2019 at 9:59 pm #91580
KeymasterTo make block cost field mandatory you can use the following code snippet
function make_booking_block_cost_required($fields) { $required = array( 'custom_attributes' => array( 'required' => true, //'required_message' => 'Change default required message from here', ), ); $fields['_wc_booking_block_cost'] = array_merge($fields['_wc_booking_block_cost'], $required); return $fields; } add_filter('wcfm_wcbokings_cost_fields', 'make_booking_block_cost_required');Add this code to your child theme’s functions.php
- The topic ‘Mandatory fields in product edit screen’ is closed to new replies.
