Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Marketplace force WordPress Dashboard RTL view (WPML)
- This topic has 6 replies, 2 voices, and was last updated 7 years ago by
- January 5, 2019 at 11:58 am #42313
d-n-13
ParticipantHello wcfm
with latest updates new issue appeared on the Marketplace plugin only (Deactivating the plugin fixes the issue)
I have my WordPress dashboard always appear LTR even if I change to RTL languages, but when i active Marketplace it will always change view to broken RTL : https://cdn.wpml.org/wp-content/uploads/2018/02/1506425-_Moroori_Elearning_.png?x52277
Now I have Marketplace deactivated so I can edit my RTL content until you fix the issue.
- January 5, 2019 at 12:17 pm #42315
That’s something impossible.
First of all, we didn’t anything related to WPML in latest update.
And, it’s at wp-admin, where that plugin does not have any control!
Still, we are checking this once.
- January 5, 2019 at 12:23 pm #42320
d-n-13
ParticipantYes, please check, disable the plugin and see.
- January 5, 2019 at 1:42 pm #42336
MemberOK, checking this.
- January 5, 2019 at 2:20 pm #42344
I have just checked by disabling WCFM and WCFM Marketplace but still wp-admin menu comes at let for Arabic – https://ibb.co/yFGCB51
It’s may be due to something else.
- January 5, 2019 at 2:39 pm #42352
d-n-13
ParticipantI’ve checked now, and it works fine now.
I don’t know what was causing the issue, but I cannot replicate it again!
I would like to mention that you disabled the cache plugin and I deleted all website caches from cPanel + Cloudflare, idk if that has anything to do with fixing the issue but glad the issue is no where to be found.
Sorry to bother you about this.
- January 5, 2019 at 3:15 pm #42358
MemberI have disabled your caching plugin “SG Optimizer” as well.
May it was a caching issue.
- The topic ‘Marketplace force WordPress Dashboard RTL view (WPML)’ is closed to new replies.
