Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Membership General Options
- This topic has 17 replies, 2 voices, and was last updated 6 years, 7 months ago by
- November 22, 2018 at 7:04 pm #37557
Mustafa
Every time after updating the plugin. All the customization in emails content is reset to default at “Membership General Options”.
Can you please fix this?
- November 22, 2018 at 7:43 pm #37561
Opps! But how this even possible. There is no update for WCFM Membership.
Really strange one! We are definitely checking this.
- November 27, 2018 at 6:30 am #38292
Mustafa
ParticipantYes, I am really tired from updating the content every time there is a plugin update. Looking for your support for fix this.
Also, how to enable rich editor for those content as they are displayed with HTML tags to me?
Regards,
- November 28, 2018 at 7:48 am #38464
MemberThat’s really something strange!
All WCFM setting restore for you or only membership setting?
“Also, how to enable rich editor for those content as they are displayed with HTML tags to me?”
– Please show me screenshot for this.Thank You
- November 28, 2018 at 12:29 pm #38514
- November 29, 2018 at 10:42 am #38595
MemberStrange one! Never heard such thing before.
How stored value changed by plugin update?Well, is this reset on which plugin update? Only WCFM or any plugin!
- December 2, 2018 at 11:19 am #38812
Mustafa
ParticipantOnly on WCFM plugin update.
What about rich editor?
- December 3, 2018 at 8:06 am #38873
WCFM dashboard all editors look like this -> https://ibb.co/KrST2dr
But as I see here -> https://wclovers.com/wp-content/uploads/2018/11/sss21.jpg
Your editors are looks different, is there any other plugin which controlling this?Well, be sure “Visual Editor” option not disabled for your account -> https://ibb.co/NnRRb2t
- December 3, 2018 at 8:17 am #38877
Mustafa
ParticipantI don’t have any plugin controlling the editor. “Visual Editor” option is not disabled.
Is there anything from my side to debug this?
- December 3, 2018 at 8:36 am #38883
It’s difficult to guess which disable this.
There has many plugins which disable this by force, no setting even available.
Well, can you allow me to check this once!
Then please send me site details here – https://wclovers.com/woocommerce-multivendor-customization/
- December 4, 2018 at 6:10 am #38968
Mustafa
I checked JS console as you suggested. Editor is working now after tweaking Autoptimize plugin. But when vendor goes to setting page it freezes at “Loading…” and does not show any content. I see the following error at the Console Log:
Failed to load resource: net::ERR_TUNNEL_CONNECTION_FAILED
Uncaught TypeError: progressbar.progressbar is not a function
at HTMLDocument.<anonymous> (wcfm-script-wcfmmarketplace-settings.js?ver=5.2.1:25)
at i (jquery.js?ver=1.12.4:1)
at Object.fireWith [as resolveWith] (jquery.js?ver=1.12.4:1)
at Function.ready (jquery.js?ver=1.12.4:1)
at HTMLDocument.K (jquery.js?ver=1.12.4:1)Thank you
- December 4, 2018 at 7:37 am #38971
Member - December 4, 2018 at 8:13 am #38974
Mustafa
ParticipantStill the same error. If I uncheck “Aggregate JS-files” the rich editor is working but the setting page does not.
If I disable all “JavaScript Options”, setting page still does not work and I see this:
GET https://code.jquery.com/ui/1.12.1/jquery-ui.js?ver=4.9.8 net::ERR_TUNNEL_CONNECTION_FAILED
jquery-migrate.min.js?ver=1.4.1:2 JQMIGRATE: Migrate is installed, version 1.4.1
wcfm-script-wcfmmarketplace-settings.js?ver=5.2.1:25 Uncaught TypeError: progressbar.progressbar is not a function
(anonymous) @ wcfm-script-wcfmmarketplace-settings.js?ver=5.2.1:25
i @ jquery.js?ver=1.12.4:1
fireWith @ jquery.js?ver=1.12.4:1
ready @ jquery.js?ver=1.12.4:1
K @ jquery.js?ver=1.12.4:1 - December 4, 2018 at 9:30 am #38978
Can you check once by disabling Autoptimize?
Is there any other caching plugin?
- December 4, 2018 at 9:38 am #38982
Mustafa
ParticipantNo other cache plugin. I disabled Auoptimize and still the setting page not showing up correctly.
- December 4, 2018 at 9:44 am #38985
MemberThis reply has been marked as private. - December 4, 2018 at 10:54 am #38993
Mustafa
ParticipantThis reply has been marked as private. - December 4, 2018 at 5:12 pm #39025
MemberSorry, I marked this private.
- The topic ‘Membership General Options’ is closed to new replies.
