Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › membership page layout
- This topic has 6 replies, 2 voices, and was last updated 7 years, 2 months ago by
kaloomee.
- August 9, 2019 at 9:32 am #75891
kaloomee
On the wcfm memberships page the membership description does not allow container height
My page hides text if description more than 2 lines – See screenshot https://nimb.ws/DrdRx8
Is it possible to resize this container please? https://www.kaloomee.com/shop-memberships/Thanks
KaloomeeAttachments:
You must be logged in to view attached files. - August 12, 2019 at 9:01 am #76213
Member - August 12, 2019 at 9:33 am #76225
kaloomee
ParticipantThank you for looking
Yes, I trimmed the text so it would fit but would like to show more text if possible
I have now added more text to demonstrate the issue to you
Please check same link again and you will see issue (Standard plan)
Thank you - August 13, 2019 at 5:08 am #76345
Well, as I see you have used HTML for this descriptions. can you please show me screenshot for that, hope there is no broken HTML inserted!
It should automatically adjust table head as per description content – https://ibb.co/8DF5nqq
- August 13, 2019 at 9:43 am #76410
kaloomee
ParticipantThank you for reply
Here is :-
Your very own shop within the Kaloomee marketplace.</br>
READ MORE HERE!</br>
Your very own shop within the Kaloomee marketplace</br>
READ MORE HERE!</br>As you can see, I am no coder, usually copy and paste code from some help site
Also screenshot attached
In the image that you included, Have you used html? – I have only used </br> to provide line break as no new line was added if I did notIf you did, would you please add code here
- August 20, 2019 at 5:17 am #77389
Well, HTML is fine. I have used same content – https://ibb.co/MZwpqxh and it’s working fine – https://ibb.co/bPkpzgJ
- August 20, 2019 at 8:51 am #77476
kaloomee
ParticipantHmm, Very puzzling
Thank you for testing for me, Now have to figure out what is the difference on my site.
- The topic ‘membership page layout’ is closed to new replies.
