Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Membership Subscription Menu not showing(ultimate)
- This topic has 1 reply, 2 voices, and was last updated 5 years, 11 months ago by
- September 24, 2019 at 6:25 pm #83414
soyoungbaekenny
ParticipantHi there, I reached by email asking about not being able to change membership subscription name from ‘Products’.
I found the reason and I realised that currently I am not getting ‘VARIABLE SUBSCRIPTION’ as an option. I am using Simple > Virtual option hence the reason it wouldn’t allow me to change anything else unless I input all required fields which doesn’t apply to a subscription.Currently I have Simple, Variable, Grouped, Affiliated products. How do I fix that?
Also I DON’T HAVE THE SUBSCRIPTION Menu like how it is showing in Documentation. I cannot currently check who signed up for a subscription.
I am using Ultimate and Group as well.
You must be logged in to view attached files. - September 26, 2019 at 1:26 pm #83740
Simple Subscription and Variable Subscription product options comes from WC Subscription plugin.
You have to install that plugin to have those product types.
Here is that plugin – https://drive.google.com/file/d/12VfYeIcs0Dd6i9HkxMyvq0iRF7BEOAph/view?usp=sharing
Install and take a look.
- The topic ‘Membership Subscription Menu not showing(ultimate)’ is closed to new replies.
