Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
03Day 01Hr 03Min 05Sec
Poila Boishakh
Membership users number isn't correct.
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Membership Membership users number isn't correct.
Viewing 1 reply thread
    • #25063
      d-n-13
      Going to Memberships will show you all membership created and number of User(s), I don’t know if I’m mistaken but I don’t think it is showing the number correctly. Check attached screenshots.
      Note : I think same problems happens for Groups too.
    • #25114
      We will definitely check this.
      Sometimes, if user deleted from system then this may happen.
      Between, you may check associate vendors list at Groups Manage. It will help you to re-confirm this.
  • The topic ‘Membership users number isn't correct.’ is closed to new replies.
