Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Minor Bug: Integration Wholesale Suite Plugin
- This topic has 3 replies, 2 voices, and was last updated 5 years, 11 months ago by
- August 30, 2019 at 11:47 am #79217
shitT
I’m not quite sure you picked up this one up from the last thread (https://wclovers.com/forums/topic/wcfm-ultimate-product-editor-buggy-with-wpml/#post-79108). So I open a new ticket here.
I use the wholesalesuite plugin from Rymera, which is on your compatibility list.
For vendors, when editing the products in the store manager, the “rule” field of the quantity based pricing appears on the english translations. It should be hidden.
I illustrated my case here to make it clearer for you:
– French (product language): Everything is OK – you see that quantity based pricing is enabled: https://ibb.co/0YrQW5C
– German translation: Everything OK – The wholesale pricing block is hidden correctly: https://ibb.co/xgvcC7Y
– English translation: Not OK – A “rules field” from wholesale plugin appears: https://ibb.co/JBnzFv0As the user can’t start anything with this residual “rule” field, it is a minor bug for me. Still, it doesn’t look very good for the users.
Can you check this in a spare minute?
Thanks for your dedication!
- September 2, 2019 at 9:14 am #79574
MemberDon’t worry, we will take care of this in next update.
- September 3, 2019 at 8:18 am #79768
shitT
ParticipantWorks fine now. Thanks a lot for solving this in the last update!
- September 4, 2019 at 8:45 am #79961
MemberThanks for the confirmation 🙂
- The topic ‘Minor Bug: Integration Wholesale Suite Plugin’ is closed to new replies.
