Modify default values for WooCommerce bookings fields
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Modify default values for WooCommerce bookings fields
Viewing 1 reply thread
    • #88791
      Zeljo
      I would like to modify the default values in the product edit screen for the WooCommerce booking fields. Please see the screenshot for more details. Is this possible?
      In this example, I would like to set the field “Booking duration” to have the default value “Customer defined blocks of…” instead of “Fixed blocks…”. And I would like to set the Maximum duration (when the “Customer defined blocks..” is selected) to unlimited, or at least 365.
      I’ve tried doing this with your filter ‘wcfm_wcbokings_general_fields’, but it does not seem to allow setting of default values, and if I override the value in the filter, then those values are always shown instead of the saved ones.
    • #90812
      Well, this require custom coding.
      You may contact us here for the purpose – https://wclovers.com/woocommerce-multivendor-customization/
  • The topic ‘Modify default values for WooCommerce bookings fields’ is closed to new replies.
