Diwali
00Day 04Hr 35Min 17Sec
Diwali
Modifying shipping costs among multi-vendors Then to the customer location
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Modifying shipping costs among multi-vendors Then to the customer location
Viewing 3 reply threads
    • #129290
      abbasi.aye
      Hello all,
      Thanks for the great plugin. We are new to WordPress world, but we find that this is the closest plugin to our target.
      We are aiming to modify the shipping cost at the checkout page. The modifying should be to consider the store’s zone (we don’t have postal code in our country) and the customer zone. Such zone will be a drop-down menu for the customer to choose among in the check out page. Then we will have to calculate a fixed rate among the stores, and sum it up, and one shipping cost from a select store’s zone to the customer.
      To do this logic I think We need to be able to read the stores which are shown at the final purchase step (checkout page), used by the customer.
      How to get the stores from the customer cart?
      Would you kindly help us with the above logic?
    • #129432
      Keymaster
      Thanks for giving our plugin a try.
      You can retrieve the store info from WC cart object like the following-
      $items = wc()->cart->get_cart();
      foreach ( $items as $item => $values ) {
          $product = wc_get_product( $values['data']->get_id() );
          $vendor_id = wcfm_get_vendor_id_by_post( $product->get_id() );
          if ( $vendor_id ) {
              $store_user = wcfmmp_get_store( $vendor_id );
              $shop_name = $store_user->get_shop_name();
              $url = $store_user->get_shop_url();
              $address = $store_user->get_address();
      wcfmmp_get_store function returns a WCFMmp_Store class object. You can get all the store details from this object. I’ll suggest you visit this class once. Path: wc-multivendor-marketplace\core\class-wcfmmp-store.php
      Thank You!
    • #130249
      abbasi.aye
      Thanks a lot of the help
      In order to achieve the above target, we have two snippets,
      1. Snippet-1 to add a drop-down menu in the checkout page to obtain the customer’s special sub-region.
      2. Snippet-2 to fetch the selected value from the previously added drop-down menu (say store it in $user_selected_field), then use it and also using the stores in the cart to modify the shipping rate.
      Can you help me finding a way to get the selected value of selected value from drop down from the checkout page class?
      2. Snippet-2 Looks like:
      define( ‘WP_DEBUG’, true );
      add_filter( ‘woocommerce_shipping_method_add_rate_args’, ‘AA_shipping_extra_per_product’, 100, 2 );
      function AA_shipping_extra_per_product( $args, $shipping_method ) {
      /* Interacting with dropdown menue code
      $arr_co_fields = wc()->checkout()->get_checkout_fields();//($fieldset = ‘shipping’);
      $user_selected_field = $arr_co_fields[‘billing’][‘billing_city’];//$_POST[$arr_co_fields[‘billing’][‘billing_city’]];
      //$user_selected_field = $_POST[‘dropdown’]; // I’m not sure to read selected value by customer from drop-down menu
      print_r($user_selected_field);
      /* cart info
      $product = wc_get_product( $values[‘data’]->get_id() );
      if ( $vendor_id ) {
      // decision on extra shipping rate
      $extra_ship = 0;
      if ($vendor_id == 2 && $user_selected_field =2){
      $shippnig_zone = 2
      $extra_ship +=20;
      } elseif($vendor_id == 3 && $user_selected_field =3){
      $shippnig_zone = 3
      $extra_ship +=40;
      $args[‘cost’] = $extra_ship + 1;
      return $args;
    • #131993
      Keymaster
      Check out the following snippet and build your logic on top of it-
      add_filter( 'woocommerce_checkout_fields', 'woocommerce_checkout_field_editor' );
      // Our hooked in function - $fields is passed via the filter!
      function woocommerce_checkout_field_editor( $fields ) {
          $fields['billing']['customer_zone_dropdown'] = array(
              'type'     => 'select',
              'required' => true,
              'label'    => __( 'Customer zone' ),
              'class'    => array( 'form-row-wide', 'address-field' ),
              'options'  => array(
                  ''      => 'Choose zone',
                  'zone1' => 'This zone add $10',
                  'zone2' => 'This zone add $20',
                  'zone3' => 'This zone add $30',
          return $fields;
      add_filter( 'woocommerce_shipping_method_add_rate_args', 'AA_shipping_extra_per_product', 100, 2 );
          if ( ! is_checkout() || empty($_POST['post_data']) )
              return $args;
          $arr_co_fields = wp_parse_args( wc_clean( wp_unslash( $_POST['post_data'] ) ) );
          $user_selected_field = isset( $arr_co_fields['customer_zone_dropdown'] ) ? $arr_co_fields['customer_zone_dropdown'] : '';
          $extra_cost = 0;
          if ( ! (empty( $args['package'] )) && isset( $args['package']['vendor_id'] ) ) {
              if ( $user_selected_field === 'zone1' ) {
                  $extra_cost = 10;
              } elseif ( $user_selected_field === 'zone2' ) {
                  $extra_cost = 20;
              } elseif ( $user_selected_field === 'zone3' ) {
                  $extra_cost = 30;
          $args['cost'] += $extra_cost;
          return $args;
      Please note, it will work only for Zone shipping. Thank You!
  • The topic ‘Modifying shipping costs among multi-vendors Then to the customer location’ is closed to new replies.
