Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Multi Currency
- This topic has 9 replies, 3 voices, and was last updated 6 years, 8 months ago by
Fany VanDaal.
- February 24, 2019 at 8:59 am #49767
victor natius
GuestHi guys, nice work so far. Please can you guys implement an option whereby vendors can add product according to their location currency or according to the vendors currency selection. Please can this be achieved?
- February 25, 2019 at 8:58 am #49966
Well, we have tried this many times to integrate multi-currency plugins, but issue comes at report.
None, of these plugins support WC Reports, so at the end everything looks messy!
So, we prefer to avoid this, at-least there is no useful solution available.
- February 27, 2019 at 4:53 am #50284
victor natius
Guestok thanks.. But can you help with a suggestion like can the system currency be automated by location without affecting the plugin? Like when a client from U.K opens the website, he should see Euro, when a client from U.S.A opens the website, he should also see USD. do you have a good suggestion for this. Thanks
- February 27, 2019 at 10:59 am #50348
Are you using WPMP, then use it’s default multi-currency option.
- February 28, 2019 at 6:58 am #50495
victor natius
GuestSorry what do you mean by WPMP. Can you be specific in details.. Thanks
- February 28, 2019 at 8:50 am #50511
MemberSorry, my fault.
I want to mention, WPML
- February 28, 2019 at 4:11 pm #50631
victor natius
Guestno i dont use WPML, is there a good plugin for geolocation currency that will support your plugin also
- March 1, 2019 at 8:38 am #50698
“we have tried this many times to integrate multi-currency plugins, but issue comes at report.”
– I already mentioned you the reason. If you find out a multi-currency plugin which supports WC reports, we are happy to integrate that with WCFM.
Check this plugin – https://gajelabs.com/product/scd/
It says, it works with all multi-vendor plugins and WCFM as well.
But we never test this, you may try .Thank You
- March 2, 2019 at 8:34 am #50848
victor natius
Guestok i will try it out
- March 16, 2019 at 11:43 am #52983
Fany VanDaal
Participantto: victor natius
please, have you tried the plugin?
It works?
Thanks for the information.
- The topic ‘Multi Currency’ is closed to new replies.
