wcfm-santa
-363Day -1Hr -30Min -58Sec
wcfm-santa
Multiple Roles for Store Vendors
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Multiple Roles for Store Vendors
Viewing 3 reply threads
    • #103683
      immanuel
      I am just starting you use WFCM.
      I want to assign other custom and built-in roles to the vendors on my site. I’m using a multiple user role plugin, but I am not able access any other role outside of the store vendor role when its active. For example, I will add Editor as the primary role and Store Vendor as the secondary, but the Store Vendor is the only one displayed for the user. The same happens vice versa.
      Is there a way to assign multiple roles to Store Vendors?
    • #105740
      You may assign other user role to existing vendor users.
      But if any existing user applied for vendor and become so then his roles will be updated with “Store Vendor” role.
    • #105741
      Vendor users require some special permissions, if they are associated with other roles then things do not work properly!
    • #131411
      S Charlton
