Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Delivery › Multiple shipping for vendors
- This topic has 12 replies, 3 voices, and was last updated 6 years, 8 months ago by
- December 11, 2019 at 5:12 pm #97040
viktor.creator
ParticipantHi, I have a few questions.
1. Is it possible to disable shipping methods for vendors, that are created in the admin panel (now they work globally for all vendors, I want the vendor to decide which country he wants to shipp to and in what shipping method)?
Shipping zones work well, but my site uses delivery by weight and by zone at the same time.
2. Can vendors use delivery by weight and by zone at the same time? - December 12, 2019 at 4:51 am #97131
aemr45
ParticipantHi, i’m interested in this too.
- December 12, 2019 at 5:25 pm #97239
Shipping zones work well, but my site uses delivery by weight and by zone at the same time.– Admin may create 100 shipping zones. But if vendor setup shipping cost for 2 zones then they will able to only in those two zones. For other zones, it will show message “NO shipping method found” at checkout.
– No, one vendor may use only type of shippingThank You
- December 12, 2019 at 6:31 pm #97248
viktor.creator
ParticipantNo, maybe we are talking about different things, vendors should not see admin delivery methods…
Only these plugins are active:
WCFM – WooCommerce Frontend Manager – Version 6.3.5
WCFM – WooCommerce Multivendor Marketplace – Version 3.2.6
WCFM – WooCommerce Multivendor Membership – Version 2.7.4
WooCommerce – Version 3.8.1Theme:
Twenty Nineteen – Version: 1.4Thank You!
You must be logged in to view attached files. - December 17, 2019 at 2:50 pm #97745
viktor.creator
ParticipantHello, do you have any news?
- December 22, 2019 at 10:36 am #98459
Well, if Vendor does not set any shipping method then it’s showing Admin setup shipping methods. Do you want to disable these?
- December 22, 2019 at 2:48 pm #98473
viktor.creator
ParticipantYes, I want to disable this.
- December 24, 2019 at 11:17 am #98901
Are you using any other third party shipping plugin?
- December 24, 2019 at 3:14 pm #98938
viktor.creator
ParticipantHello, yes, I’m using WooCommerce Weight Based Shipping – https://wordpress.org/plugins/weight-based-shipping-for-woocommerce/
- December 28, 2019 at 11:55 am #99695
MemberCan you please disable this and check once!
- January 4, 2020 at 4:00 pm #100853
viktor.creator
ParticipantCan you take a closer look at the issue? I wrote what the problem is above and sent screenshots! I have already explained with which plug-ins to test and with the default theme. I bought a plugin from you, but your support works disgustingly slow and says nothing intelligible!
You must be logged in to view attached files. - January 7, 2020 at 6:35 pm #101258
viktor.creator
ParticipantHey guys, waiting for your reply. It’s taking way to long to get back to us. We have a premium version that we bought and can’t further use the plugin until further clarification is made on the shipping feature.
- February 6, 2020 at 10:33 pm #105919
MemberHope this is already resolved for you using custom coding.
- The topic ‘Multiple shipping for vendors’ is closed to new replies.
