Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › New products with the same name are not grouped & The attributes are not copied
- This topic has 18 replies, 3 voices, and was last updated 7 years, 2 months ago by
Jordil.
- April 25, 2018 at 5:28 pm #22362
Jordil
GuestHello, I have two questions:
1. I’ve checked “let different vendors sell the same product” button in WC marketplace. Then, when a vendor add an existing product, with the same name, added for another vendor sometimes the new added product is not grouped to the first one in the shop. This happens when the existing product is an original (not a copy). If the product choosed is a duplicated (with “copy” in the name) there is no problem:
2. When a vendor add a new product copy of the existing product, the “attributes” are not copied:
- April 27, 2018 at 6:13 am #22419
1. You are right, WC Marketplace latest single product multi-seller is not working properly with WCfM. We will fix this in next update.
2. Just checked, attributes are copied for duplicate products, no issues there.
- April 27, 2018 at 12:35 pm #22433
Jordil
Maybe there are some incompatibilities with some plugin….
- April 27, 2018 at 2:26 pm #22441
MemberDo you have any plugin like duplicator?
- April 27, 2018 at 2:43 pm #22442
Jordil
GuestHi again,
Well, I think I’m doing a mistake. Attributes copy is it working with the free version?
- April 27, 2018 at 3:04 pm #22443
Normal duplicate product feature is not part of WCfM Free. You are also not allowed to use pre-defined WC attributes in Free.
But there is no restriction on coping things, whether it’s Free or Ultimate.
- April 27, 2018 at 4:03 pm #22445
Jordil
GuestI’m wondering why the “policies” are copied but no “attributes”
- April 27, 2018 at 5:21 pm #22447
Can you provide me a demo vendor access to check you attributes?
- April 27, 2018 at 8:01 pm #22452
Jordil
GuestThis reply has been marked as private. - April 27, 2018 at 8:41 pm #22458
Bingal
Thanks for the test account.
You have disabled “Attributes” for vendors?
Still I have just created this product by copy and attributes are copied from old product – https://agnljpzg.lucusvirtual.es/producto/el-vibora-no001-2/
Can you please show me screenshot which you think not copied? May be I am misunderstood your query!
- April 27, 2018 at 9:17 pm #22461
Jordil
At this moment the capability for vendors is disabled, but when are not disabled the result is the same.
Here you are the screenshot of your duplicate, I can’t see the attributes.
Maybe I did not explain it too much…
- April 27, 2018 at 9:30 pm #22462
MemberAhh … it’s product description, right? not attribute!
- April 27, 2018 at 9:37 pm #22463
Jordil
GuestOld product screenshot
- April 27, 2018 at 9:39 pm #22464
Jordil
GuestNo, no sorry, Atributtes appear in the page like “informacion adicional”, see the second screenshot
- April 27, 2018 at 9:51 pm #22465
MemberPossibly now I am getting the issues.
When I am duplicating a product it is perfect in Draft mode – https://agnljpzg.lucusvirtual.es/?post_type=product&p=276
But if I publish this then Attribute will loose as you have disabled that from Capability.
- April 27, 2018 at 10:03 pm #22466
Jordil
Guestok, so I have to change the capability to no diabled?
- April 27, 2018 at 10:05 pm #22467
MemberFor now keep that enabled, at least till the WCfM next update.
- April 27, 2018 at 10:06 pm #22468
Jordil
GuestTry yo duplicate old product from another vendor, the attributes not appear
- April 27, 2018 at 10:08 pm #22469
Jordil
Guestok,
thank you
- The topic ‘New products with the same name are not grouped & The attributes are not copied’ is closed to new replies.
