Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Not showing Vendor order details(Earning, Withdrawl, Refund)
- This topic has 14 replies, 2 voices, and was last updated 7 years, 6 months ago by
- September 13, 2018 at 6:25 am #31543
kasaga311
We are having issues with the Orders when using the WCFM Marketplace.
The Dashboard, Ledgerbook, Reports – all show Zero (0) values for the Earnings, Refund, Withdrawl even though we have placed Orders and Completed them.
Can you tell us what is wrong with our setup?
–Kasaga - September 14, 2018 at 5:28 am #31606
I have checked the site and found that there is no recent orders.
Old orders can not be visible under vendor dashboard, those were placed when you had WC Marketplace.
Kindly add a new order and take a look.
I have just test and it’s showing – https://ibb.co/b43wUp
Between, i have also updated “Product Quick Manager” plugin, please check is this working or not!
- September 14, 2018 at 6:13 am #31615
kasaga311
ParticipantThis reply has been marked as private. - September 14, 2018 at 6:19 am #31617
kasaga311
ParticipantThis reply has been marked as private. - September 14, 2018 at 7:10 am #31619
The issue is not the orders listing. – If you placed a new order it’s not showing under vendor’s orders page? But it comes for my test vendor – https://ibb.co/b43wUp
It is not showing the calculations on the Dashboard and in the reports. – This is because of this setting – https://ibb.co/djixkU
as you have set only “completed” status here so other order status not considered as sales. And I think those orders are not yet completed!Thank You
- September 14, 2018 at 10:11 am #31626
kasaga311
ParticipantThis reply has been marked as private. - September 17, 2018 at 10:44 am #31787
kasaga311
Have you had a chance to look into the issue with the login details that I gave above?
We are having issues with the Orders not showing up in the Customer Orders screen as well.
Please login with the credentials that I gave in private and let us know what you think is the issue.
- September 17, 2018 at 10:47 am #31788
- September 18, 2018 at 7:29 am #31918
kasaga311
Any update on the issues?
–Kasaga - September 18, 2018 at 7:35 am #31919
I am working on this, will update you today EOD.
- September 19, 2018 at 11:34 am #32003
Kindly add this line to your child theme’s functions.php
add_filter( 'wcfm_is_allow_store_followings', '__return_true' );This will add “Followings” tab in store page, but this will work after WCFM Marketplace next update.
- September 22, 2018 at 9:45 am #32212
kasaga311
ParticipantThis reply has been marked as private. - September 22, 2018 at 5:08 pm #32265
I have just checked this and this is really strange!
Do you have any custom code related to following-followers in theme’s funstions.php?
Then just remove all those except this – add_filter( ‘wcfm_is_allow_store_followings’, ‘__return_true’ );Thank You
- September 24, 2018 at 6:27 am #32356
kasaga311
ParticipantThis reply has been marked as private. - September 24, 2018 at 3:31 pm #32398
MemberOK, I am checking.
- The topic ‘Not showing Vendor order details(Earning, Withdrawl, Refund)’ is closed to new replies.
