Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Not working on WCFM
- This topic has 4 replies, 2 voices, and was last updated 6 years, 6 months ago by
- September 25, 2019 at 7:51 am #83516
jorsenmejia
ParticipantTYPES is not working on wcfm please help me fix this please refer to the attachments
You must be logged in to view attached files. - September 26, 2019 at 3:32 pm #83770
– What is “TYPES”? Do you mean “Toolset” plugin?
If so, then it does not offer any custom port type, it allow to add custom fields for product post. You will see those fields at product manager -> tabs area
- September 27, 2019 at 6:48 am #83928
jorsenmejia
Participantdid you check the screenshot I send? I off simple, variable, grouped, external and downloadable but still working on product types
- September 28, 2019 at 11:05 am #84204
jorsenmejia
Participantany update?
- September 30, 2019 at 11:00 am #84447
https://wclovers.com/wp-content/uploads/2019/09/Capture-5.png – is this from Admin dashboard or as Vendor?
Capability setting only work for vendors.
If you are using WCFM – Group addon then recheck group capability as well.
- The topic ‘Not working on WCFM’ is closed to new replies.
