Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Nothing Happened after "Click here" on Chosen MEMBERSHIP PLAN
- This topic has 15 replies, 2 voices, and was last updated 5 years, 11 months ago by
Sarmistha Chakraborty.
- April 28, 2020 at 9:41 pm #124355
popandbloom
Participanthello,
I have created my custom membership design. I copy and paste the subscribe button url that was provided, but nothing happened after I clicked on it.
How can I achieve the following steps:
1) Choose Plan – click here – redirect to “REGISTRATION FORM”
2) Register
3) Thank you pageRegister page is set up
Thank you page is set upJust no redirect to Registration form after Chosen membership. The page stays the same on membership page.
Please consult.
Thank you - April 29, 2020 at 2:21 pm #124576
After create custom Membership page, You just have to use membership subscription button short code for creating buttons for that table – https://ibb.co/NNFNxxK
And set that custom plan page here – https://ibb.co/fS4FST0
You may change it’s colors from Membership Setting -> Style – https://ibb.co/7CzBxJP
And Set “Disable Store Setup Widget” turn-on (WCFM store dashboard -> Settings -> Marketplace settings)
For vendor Registration browse the “custom Membership page” which was you have created.Thanks.
- April 30, 2020 at 12:50 pm #124977
popandbloom
Thank you. It was more of the colors that I would like to change.
I followed your suggestion to change the colors in STYLE (membership) but nothing happened to my colors, still all default blue colors.
See attachment
Please advise if there’s a default setting I need to change!Thank you
You must be logged in to view attached files. - April 30, 2020 at 1:09 pm #124982
To change “Membership body” background color you need to change “Table Body Background Color” color from style settings.
Please be advised it will work with our default Membership plan page (which contain [wcfm_vendor_membership] shortcode), in your custom membership plan page, if you are using different HTML structure/classes then it will not work.Thanks.
- April 30, 2020 at 1:24 pm #124984
popandbloom
Participanthihi,
thats what I did, i changed many different colors, but still default blue.
I don’t know how to set HTML structure / classes, do i didn’t do that. or how can i check?
ps fyi: I’m using a multisite, and this is for my secondary site. i don’t think this should be a problem, not sure.
You must be logged in to view attached files. - April 30, 2020 at 9:31 pm #125137
Firstly checked by “inspecting element”(to “inspecting element” right click on the webpage and go to “inspecting element”) whether the “div” has the class – “wcfm_membership_box_head” and whether your changeable color(from settings) is reflected or not.And you have to change “style settings” in all the sub-site (from WCFM Dashboard)
You must be logged in to view attached files. - April 30, 2020 at 9:52 pm #125149
popandbloom
ParticipantHihi
thanks! I don’t see it, see screencap.
So how can fix this issue?
You must be logged in to view attached files.- April 30, 2020 at 9:59 pm #125154
No, you haven’t selected the actual “div”. It’s okay. Please send the URL.(with access). We will check the page.
- April 30, 2020 at 10:04 pm #125156
popandbloom
ParticipantThis reply has been marked as private.- April 30, 2020 at 10:31 pm #125165
Custom style is not added, please share us the site details, we need to check the settings.
- April 30, 2020 at 11:24 pm #125178
popandbloom
ParticipantThis reply has been marked as private.- May 1, 2020 at 3:13 pm #125363
MemberThis reply has been marked as private.
- May 1, 2020 at 7:32 pm #125454
popandbloom
ParticipantThis reply has been marked as private.- May 1, 2020 at 7:45 pm #125458
- May 1, 2020 at 10:09 pm #125509
popandbloom
ParticipantThis reply has been marked as private.- May 3, 2020 at 12:13 pm #125931
