Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
02Day 19Hr 22Min 26Sec
Poila Boishakh
Number of products per page
Viewing 4 reply threads
    • #80174
      Anis Rahaman
      Hi
      I have set ‘Products per page’ to 12, but it only displays 10 product per page
      Please see the attached file for more info. Can you advise how to fix this?
    • #80397
      Well, possibly you have set this setting after creating this vendor.
      Now for this vendor you have to change this form his store setting. https://ibb.co/LSd7hyB
      Or, you may add this code to your site and apply rule globally –
      add_filter( 'wcfmmp_store_ppp', function( $post_per_page ) {
      	$post_per_page = '12';
      	return $post_per_page;
      }, 50 );
    • #86134
      Jamie O’Reilly
      This worked for us too : )
    • #123436
      L Stewart
      I have used this code, but in the vendor settings they can still see the ‘products per page’ option. So I suppose it will also appear int he set up wizard. How can I remove the visibility for vendor to enter this?
    • #123526
      Keymaster
      To hide the settings from vendor dashboard you will also need to add the following snippet-
      add_filter('wcfm_marketplace_settings_fields_visibility', function($store_visibility) {
          if(wcfm_is_vendor() && isset($store_visibility['store_ppp'])) {
              unset($store_visibility['store_ppp']);
          return $store_visibility;
      Let me know how this goes.
