I need to use “ELEX DHL Express/DHL Paket WooCommerce Shipping with Print Label” Plugin for DHL Label creation. Unfortunately this plugin causes changes in wcfm vendor order view. The Order notice gets invisible and it is not possible for vendor to change order status.
Would be great if you could check that with very high urgency as my business is struggeling withput this plugin. (Elex is also informed)
Screen 1. Order with dhl plugin activated
screen 2. Order with dhl plugin deactivated
Dominique
You must be
logged in to view attached files.
