Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Order status to be only updated to order completed when ALL vendors are done
- This topic has 1 reply, 2 voices, and was last updated 5 years, 10 months ago by
- October 31, 2019 at 8:04 pm #89932
stickr.sg
When a buyer buys items from multiple vendors in a single order, a vendor can change the order status to “completed” and every vendor from the same order also sees the order as completed.
Because of that, they will miss out on the order. Please kindly help to update the WCFM such that if there are 3 vendors in the same order, it requires all 3 of them to change the status to “completed” before the whole order gets completed. If one vendor changes the order to completed, the other 2 vendors should still see it as processing status. Thank you.
You must be logged in to view attached files. - November 6, 2019 at 3:08 pm #91073
– Please disable “Order Sync” option from WCFM Admin Setting -> Marketplace Setting – https://ibb.co/64X6B1j
Also add this line to your site to mark main order completed when all vendor will mark there order completed –
add_filter( 'wcfm_is_allow_mark_complete_main_order_on_all_child_order_complete', '__return_true' );
- The topic ‘Order status to be only updated to order completed when ALL vendors are done’ is closed to new replies.
