order status with multiple vendors
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › order status with multiple vendors
Viewing 1 reply thread
    • #65087
      Allan Lee
      On a single order, it is possible to order from different vendors. However if one vendor changes the status for their part of the order, it changes the status for all vendors.
      There are two possible solutions,
      1. Allow only 1 vendor per order. I did not see a way to enforce this.
      2. Change the coding for status change on the marketplace front-end. I see that in the database there are separate entries in the the wp_wcfm_marketplace_orders so it should be possible, I will just have to dig into the code.
      Which way is recommended?
      Allan
    • #65307
      Please go to WCFM Admin Setting -> Marketplace Setting -> Disable “Order Sync” option
  • The topic ‘order status with multiple vendors’ is closed to new replies.
