Order sync – Order Status Pending not triggers woocommerce_order_status_changed
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Order sync – Order Status Pending not triggers woocommerce_order_status_changed
Viewing 2 reply threads
    • #131896
      andrea.cantore
      Dear WC Lovers,
      first of all I want to thank for you incredible plugin.
      I am currently having troubles with the order sync feature.
      It seems that changing some status, do not trigger the woocommerce_order_status_changed.
      For example the pending status it seems that is not recognized.
      I was trying to figuring it alone looking inside wcfmmp_vendor_order_status_update in the class-wcfmmp-ajax.php, but without success.
    • #132451
      What you have set “Order Sync” setting at WCFM Admin Setting -> Marketplace Setting ? https://ibb.co/t8h94vZ
      Is only “Pending” order-status will not reflected in main main order?
      Please check once only activate WooCommerce and Our WCFM plugins(all updated). And remove(keep backup) custom code if you have added.
      Let me know how it goes.
    • #132514
      andrea.cantore
      I will do the test you suggested.
      Just to be clear. The status is correctly updated, and synchronized, the problem is that, for any strange reason do not trigger the woocommerce_order_status_changed event.
      Thanks for the answer.
  • The topic ‘Order sync – Order Status Pending not triggers woocommerce_order_status_changed’ is closed to new replies.
