Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Other plugins
- This topic has 5 replies, 2 voices, and was last updated 8 years, 11 months ago by
- July 30, 2017 at 6:26 pm #11650
yx
GuestHi!
I would like ask is your plugin compatible with else plugins which WC marketplace sells, like membership-plugin and enquiry-plugins?
And can use many different types bookable types on same dashboard on same time (for example bookable, appointments and rental) or should choose only one type?
Thanks. - July 30, 2017 at 6:53 pm #11651
No, WCFM is not compatible with WCMp Membership. But just to mention WCMp own Front-end Manager is also not compatible with their Membership.
I like to mention here, we are going to launch our own WCfM Groups and Staffs, which will pretty much doing the same thing and even more.
But definitely not with Catalog Enquiry Pro.
There is no such restriction, you may install all plugins together. Just check our demo for reference, we have already installed all there.
http://demo.wclovers.com/my-accountIf you have any further queries feel free to reach us anytime.
- July 30, 2017 at 7:18 pm #11652
yx
GuestHi!
Thanks for your fast reply. Okay, that´s great to know that there not be any restriction. Does also WooCommerce Accommodation Bookings extension work with your plugin? Or do you will make it compatible if it not be yet? There is possibility to add barcodes manually. Does it makes barcodes automatically to invoices or what is this opportunity for?
Thanks. - July 30, 2017 at 7:25 pm #11653
WCFM is already compatible with Bookings Accommodation. You may go through our demo as well –
http://wcbooking.wclovers.com/my-accountInvoice Barcodes – didn’t yet think about yet. Do you have any recommended plugin for this, we will happy to integrate that.
- July 30, 2017 at 7:36 pm #11654
yx
GuestHi!
Thanks for your reply. That´s great news 🙂 And no, I don´t have any plugin for barcodes which I could recommend, because I don´t have use any yet… Just looking for opportunities 🙂 Thanks again, it looks like I will order your plugin soon 🙂
- July 30, 2017 at 7:47 pm #11659
MemberWow .. that’s great to know ????
That will be not an issue at all, but as you mention we will look into it.
Feel free to reach us anytime with any query, even regarding WooCommerce as well.
- The topic ‘Other plugins’ is closed to new replies.
