Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Page Create
- This topic has 1 reply, 2 voices, and was last updated 5 years, 11 months ago by
- September 26, 2019 at 8:35 pm #83872
muhammad.ru.zoology
ParticipantHow to create Vendor login or vendor membership page?
How to create Vendor Frontend manager page?
How to create Vendor Frontend manager or product publish page?
And why vendor can not any image upload? - September 27, 2019 at 2:58 pm #84009
Well, WCFM plugin’s pages created automatically as you will install this.
Please check this once – https://youtu.be/ZKGD1PkdgYI
Be sure you have installed this two plugins –
https://wordpress.org/plugins/wc-multivendor-marketplace/
https://wordpress.org/plugins/wc-multivendor-membership/If not, please install these two plugins, and do not skip Installation Widget.
Now, go to wp-admin -> WCFM Options -> be sure “Store Manager” page is set over there.
If it’s not there then create a page using short code
[wc_frontend_manager]
and set there.Now browse that page and go to Setting -> Dashboard Pages -> Be sure “Registration” and “Membership” pages are set over there.
If not, create those pages and set there. Page shortcodes are mentioned there under setting.Thank You
- The topic ‘Page Create’ is closed to new replies.
