Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Pay per product not working
- This topic has 17 replies, 2 voices, and was last updated 6 years, 5 months ago by
- January 9, 2019 at 8:47 pm #42872
ehaggler
ParticipantHello I am trying to create a member ship where one is paid per product. No matter what setting I select it is not working. Please clarify how this is suppose to work I followed your video. I have all your plug ins installed but the buy now button is not working.
You must be logged in to view attached files. - January 10, 2019 at 6:37 am #42890
What is happening if you click on Buy Now?
- January 10, 2019 at 6:39 am #42891
MemberPlease check, whether there is a product in your site with name “Product limit credit purchase”?
If not, then go to Membership setting and press save once.
- January 10, 2019 at 2:02 pm #42943
ehaggler
Participanthello
nonthing happens the buy now button is not working.
I do not have this any place in products.
I have done this over and over and still no change.
- January 11, 2019 at 6:45 am #43075
Can you please check one thing?
Open Google Chrome Browser console and be sure there is no JS error in page.
- January 12, 2019 at 4:40 am #43188
ehaggler
Participanthello this is what it show in google I don,t know what that means.
JQMIGRATE: Migrate is installed with logging active, version 1.4.1
jquery-migrate.js:45 JQMIGRATE: jQuery.event.handle is undocumented and deprecated
migrateWarn @ jquery-migrate.js:45
jquery-migrate.js:47 console.trace
migrateWarn @ jquery-migrate.js:47
jquery-migrate.js:45 JQMIGRATE: jQuery.fn.load() is deprecated
timepicker.js:2183 Uncaught TypeError: startdt.getTime is not a function
at checkDates (timepicker.js:2183)
at Timepicker.$.timepicker.handleRange (timepicker.js:2239)
at Timepicker.$.timepicker.datetimeRange (timepicker.js:2136)
at HTMLDocument.<anonymous> (wcfmph-script-wc-groupbuy-products-manage.js:6)
at i (jquery.js:2)
at Object.fireWith [as resolveWith] (jquery.js:2)
at Function.ready (jquery.js:2)
at HTMLDocument.K (jquery.js:2) - January 12, 2019 at 7:29 am #43205
Can you please disable WCFM – Product HUB addon and check once?
- January 12, 2019 at 5:45 pm #43236
ehaggler
Participanthello I disable it works when disable WCFM – Product HUB addon and check once is there a solution fix
- January 13, 2019 at 7:31 am #43310
Don’t worry, we will resolve this in Product HUB next update, then activate it again.
- January 13, 2019 at 5:00 pm #43367
ehaggler
ParticipantHello I have another question how can vendor add more than one pay per product at a time I want to charge 0.15 per listing but let say customer want to by 5 how can I set that up so they can buy 1 or 100 how ever many thanks
- January 14, 2019 at 4:31 pm #43510
Well, right now it’s possible to setup multiple rules but you may set 5 listing batch – https://ibb.co/wRqLPM7
- January 15, 2019 at 4:17 pm #43719
ehaggler
Participantis there a subscription plug in that works other then https://woocommerce.com/products/woocommerce-subscriptions/ because the cost is no in my budget. thanks
- January 16, 2019 at 6:28 am #43798
Certainly there is no other WC Subscription plugin available.
Here is that plugin for you – https://drive.google.com/file/d/1b5n7BIZMehsvkPxlOvQm3-7LI6MPXkIC/view?usp=sharing
Use this for now, when you will have fund get it’s license.
Have a great day 🙂
- January 20, 2019 at 9:08 pm #44512
ehaggler
ParticipantHello Is there a fix for Product HUB next update thanks
- January 21, 2019 at 9:25 am #44542
MemberNew update will be there on tomorrow.
- January 26, 2019 at 3:29 am #45236
WCFM Product HUB 1.0.4 has just released and we have taken care of this.
- April 11, 2019 at 11:20 am #57271
ehaggler
ParticipantHello Pay per product not working again. It stop working. please help.
- April 12, 2019 at 7:26 pm #57483
What issue you are getting?
Hope, you did not deleted “Pay per Product” WC Product by mistake!
- The topic ‘Pay per product not working’ is closed to new replies.
