Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Payment gateway
- This topic has 6 replies, 3 voices, and was last updated 5 years, 5 months ago by
guidomagaldi.
- April 19, 2020 at 8:54 am #120510
jennis015
ParticipantHello!! I am using a gateway from Argentina.
This one has a woocommmerce plugin. Is this useful to receive customer payment and apply commission?
And then should I configure this payment gateway with this (https://wclovers.com/knowledgebase/wcfm-marketplace-custom-payment-gateway-developers-guide/) to pay providers (Withdrawal)?Thank you!!
- April 19, 2020 at 1:00 pm #120555
Avinaba
Which payment gateway are you using? Only having a WooCommerce plugin for the payment gateway won’t suffice your needs? It needs to be made compatible for a multi-vendor environment as well.
- April 19, 2020 at 6:58 pm #120645
jennis015
ParticipantHi im using todopago https://github.com/TodoPago/
If the plugin isnt compattible, i should use only your code?
Thanks! - April 20, 2020 at 5:19 pm #120963
Avinaba
MemberMerely adding our code again won’t suffice, we have provide the support and TodoPago need to have Split paying ability for this as well, we can only comment on this once we do have a look into the API of the payment gateway.Here are the payment systems that we support currently- https://wclovers.com/wcfm-compatible-plugins/
- April 20, 2020 at 5:29 pm #120967
jennis015
ParticipantThanks for the quick reply! None of them works with Argentine ARS, i searched before. Please can you look at it the other option may be?
this is https://github.com/TodoPago/
or mercapago? https://es-ar.wordpress.org/plugins/woocommerce-mercadopago/ (but seen in another publication that was not compatible)Thanks very much.
Regards - April 20, 2020 at 5:39 pm #120974
jennis015
Participanti refer do manual the commission and withdrawal process.
- May 5, 2020 at 10:30 pm #127111
guidomagaldi
ParticipantHello! I am from Argentina as well, any news on this topic? it would be great to ave mercadopago or todopago integrated.
